Hardware AMD Radeon R9 280X, R9 270X and R7 260X Reviews
Discussion in 'Article Discussion' started by Meanmotion, 8 Oct 2013.
  1. raven1977
    raven1977 What's a Dremel?
    4 Feb 2013
    I smell Nvidia bias here, the 680 re-badge the 770 got 92% with a whopping 29/30 for value even at over £300 for a cheap 256 bit POS. Now we have the 3GB 7970 re-badge with a score of 85% and a lowly 23/30 for value even though the cheapest 280x can be had for £70 cheaper than a 770. I call BS.
  2. Harlequin
    Harlequin Modder
    4 Jun 2004
    it will be - it`ll come in at 7950 money
  3. rollo
    rollo Modder
    16 May 2008
    so £173?( which is the current price of a 7950 on scan today) If so that would make it the bargin of the century. I have my douts though. A direct $ to £ conversion puts it around £186 before vat mark btw. puts it at around the £220 mark with VAT. No $ price includes sales tax for those that are not aware of that.
  4. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    I reckon it'll be £240-£270 covering the range of stock and custom cooler/overclocked ones, with much better deals (inc Never Settle packages) available on the 7970 and such so as to clear them out, before the 280X comes down a bit more.
  5. Adnoctum
    Adnoctum Kill_All_Humans
    27 Apr 2008
    The R9-290 GPU is a new one based on the GCN architecture but heavily tweaked and physically bigger (more transistors) on the same TSMC 28nm node. It is not a "rebrand" of an existing GPU.
    AMD has a bit of a problem because TSMC has been a bit slow with their 20nm process. It is why Tahiti is 2 years old and going on 3. There is not much point doing a top->down refresh on the same node (28nm) if the tweaks don't result in much increased performance on their own. That is a lot of engineering effort (money) spent by AMD/partners for not much return. R9-290 will get its performance increase with a die size increase, and bigger chips cost more to make.
    Better to push down the current cards (which are cheap, mature and yielding in good numbers) to lower price points, which results in the R9-280/270/260. Sucks for us enthusiasts looking for the new high performance products (what are we to do if we aren't able to shove a rocket up TSMC's backside?), but it is good for those looking for price/performance products.
    Nvidia is in the same boat, hence the 6xx->7xx rebrands and the lack of new products until the end of 2014 when 20nm is available. Everybody is in a holding pattern until 20nm, while the engineering side works on behind the scenes.
    Latest ETA on TSMC 20nm is for volume production to start February 2014 for the first fab and May for follow on phases, but no doubt initial yields will be so appalling that we won't be seeing production of large chips (like GPUs) until well into 2H 2014 when the process is a bit more mature.
    If you can afford to wait a year, you'd be better off waiting for the faster cards packing more Oomph for less Juice. If you are looking for a replacement now, then I'm sure there will be good deals to be had on the R9-2xx or GTX7xx.
    The stifling effect of last-gen consoles on game performance has meant that I'm now over worrying about what number the sticker on my GPU says. I care only about performance at the moment I play, and lately I've been playing games on my low power MITX system that has an HD7750 rather than my main system. Which sucks because that is a high-end system going to waste!
  6. Panos
    Panos Minimodder
    18 Oct 2006
    Btw if someone is looking for CF in the future, a 7950-7970 can CF with an R9 280X is seems :D (there are post from other websites that tried it today)
  7. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    Yep. My 660 Ti still works out just fine. Moving along...
  8. Hustler
    Hustler Minimodder
    8 Aug 2005
    2yrs for them to come up with a re branding exercise....derp.
  9. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Except for the GTX780, the whole NVidia 7xx series is re-branding too.
  10. David
    7 Apr 2009
    Only the 770 was a rebrand.
    I want to see the R9 290 and it's UK launch price. I'm concerned nvidia has poisoned the water for us by setting 780's price at £500+, and I'm just beginning to wonder if AMD will go the same way if the 290's performance is comparable. Not that it will immediately matter to me, as I plan to keep my 670 for at least another year - neither of the launches have wowed me or made me question my decision to buy my (now 13 months old) card.
  11. Hustler
    Hustler Minimodder
    8 Aug 2005
    ..which just goes to show what an utterly boring and predictable space both the GPU & CPU market have become.
    Nothing but cynical smoke & mirror re brands and lazy 5% performance boost's.
    The whole situation sucks....ZZZZzzzzz
  12. GuilleAcoustic
    26 Nov 2010
    The GTX760 is also a GK104 based card, like the GeForce GTX 690, 680, 670, 660 Ti ... and GTX 770
  13. Panos
    Panos Minimodder
    18 Oct 2006
    At least AMD rebranding means that previous series is cheaper and better value for money :D
  14. David
    7 Apr 2009
    Based on the same GK104 GPU yes. That does not make it a rebrand. Upping the clock speeds on the 680 and calling it a 770 is a rebrand.
    The spec list on the 760 is different to that of the 670.
  15. GuilleAcoustic
    26 Nov 2010
    It still should be called a GTX 665 Ti. Those mix of old and new gen chip is very confusing for the customer. You think you're buying the new generation, but you're just buying rebranded / rearranged / tweaked previous gen.
    It's even worse with NVidia GT cards that can be 2 generation old (see GT630 and GT620 that are rebrand of fermi GT430). I've seen GT640's with GDDR5 (instead of the classic DDR3) ... you'd say "Cool", but if you look closely they use 64bit memory bus instead of 128 .... that's really misleading.
  16. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    The 1st game to have mantle implemented on it is BF4 ....which is out in a couple of years! lol
  17. rollo
    rollo Modder
    16 May 2008
    Bf4 does not launch with mantle for the record will come as a patch at a later date.
  18. Valinor
    Valinor What's a Dremel?
    30 Oct 2010
    Yeah, in December is what they're saying atm.
  19. Harlequin
    Harlequin Modder
    4 Jun 2004
    gtx 760 is a gtx 670 with higher clocks and 1 less TMU
  20. Corky42
    Corky42 Where's walle?
    30 Oct 2012
Tags: Add Tags
