Hardware AMD Radeon R9 285 Review feat. Powercolor
Discussion in 'Article Discussion' started by Combatus, 2 Sep 2014.
  1. Combatus
    16 Feb 2009
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Is that the factory applied goop ? It looks like it's been applied with a trowel.
  3. loftie
    loftie Multimodder
    14 Feb 2009
    might want to rephrase that - first page second from bottom paragraph.
    Good review though, am also interested how the 4gb version performs in BF4.
  4. DbD
    DbD Minimodder
    13 Dec 2007
    Yawn, at most a few % more performance for the price over 280 which was at most a few % more performance over the 7950 - all basically the same card with minor tweaks. If you ignore the stupidly expensive top end then graphics market is getting as stagnant as the cpu one.
  5. Corky42
    30 Oct 2012
    Or maybe the graphics market has cards to suit everyone's price and performance requirements.
  6. mikemaher205
    mikemaher205 What's a Dremel?
    14 Aug 2011
    Only a worth wile upgrade if you're coming from 5000 or 6000 series AMD cards really.
    Troll time, on GPU test graphs in games, is it worth emphasising the 30 FPS line so, at a glance, you can see if a card falls below the "acceptable playing level"?
  7. Deders
    Deders Modder
    14 Nov 2010
    Except it brings trueaudio into the mid high end.
    I am wondering if BF4's deferred rendering can't take advantage of the extra compression features that give the advantage in other games.
  8. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    One could also say 45/40 fps, or 25/20 etc. Different users have different ideas on what is acceptable. Reviewers can't cater for everyone and have to pick the criteria they consider practical.
  9. dactone
    dactone dact-one
    26 Apr 2010
    I really don't understand why it's called the R9 285 .
    Surely it should be R9 275, how can it replace the 280 if it's barely touching the sides ?
  10. MrJay
    MrJay You are always where you want to be
    20 Sep 2008
    The 285s interface and bandwidth seem low incomparison to the 280s seems odd to me.
  11. Baz
    Baz I work for Corsair
    13 Jan 2005
    While this is basically a cut-down 7950 (that I originally reviewed for bit-tech 2.5 years ago!), the thing that amazes me is the price. the 7950 launched at £350, and now this card is available for less than half that.
    While you'd certainly feel that you'd gotten good mileage from your 7950 (or 7970) if you bought one at launch, that's a huge drop in price for performance over a 2.5 year period.
    For comparison, we tested the 7950 on a 2500K, a £175 CPU at the time. In Comparison, the all new 4790K isn't that much faster, and costs even more!
Tags: Add Tags
