Hardware AMD Radeon R9 290X 4GB Review
Discussion in 'Article Discussion' started by Meanmotion, 24 Oct 2013.
  1. Gradius
    Gradius IT Consultant
    3 Feb 2009
    Passing +70C is already dangerous!
  2. Guest-16
    Guest-16 Guest
    Depends on the IC design to be honest. Most mobile chips are OK up to 100 and regularly sit in the 80s to 90s.
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Isn't temperature in IC's directly related to the expected life of the IC ?
    Or at least that's what i always thought.
  4. Panos
    Panos Minimodder
    18 Oct 2006
    For any CPU 70C+ is dangerous (especiall Intel ones).
    However the majority of the GPUs from Nvidia & AMD are happy at 90C. They give standard 3y warranty on those R9 290X either way.
  5. David
    7 Apr 2009
    Can you provide a source for that claim, because I sincerely doubt it?
    I've been pushing Intel CPUs to their limit for years. 70c+ load temps are nothing to be feared.
  6. Shirty
    18 Apr 1982
    The Core 2 Duo T5500 in my 2007 laptop begs to differ! It still regularly reaches 90°C under load, and idles between 60 to 70°C. Still going strong after six and a half years of regular thrashing.
  7. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
  8. Guest-16
    Guest-16 Guest
    Again, depends on the design.
    CPUs have a higher frequency than mobile GPUs, although mobile CPUs have a higher temperature threshold generally. For example tCase of Intel's desktop CPUs sits at ~72C, but tJunction (because BGA) of their equivalent mobile ones is 100C. Since GPUs are BGA, their junction temp will be around the same, although because the die size is far more massive the specific temp of any particular area can vary.
  9. Corky42
    30 Oct 2012
    Yea i knew IC's varied greatly in what is claimed to be the safe working temperature although i have never understood why exactly, so just guessed it was to do with the design. After all isn't the silicon they are made from all the same ?
  10. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    i really wanted to upgrade from my 7970 to something cooler/quieter, my wallet is safe ;) :D
  11. Guest-16
    Guest-16 Guest
    The actual element is the same but the process technology and IC design can differ greatly to limit electromigration or current leakage at high temperatures. Mobile phone can ICs throttle at 90C, but most are capped lower to prevent your hand melting. There's a whole variety of manufacturing designs for all industries.
Tags: Add Tags
