Graphics AMD RADEON R9 390X (unboxing)
Discussion in 'Hardware' started by penryn 2 hertz, 13 Jun 2015.
  1. Harlequin
    Harlequin Modder
    4 Jun 2004
    I disagree as the chart explicitly starts with:
    NVIDIA Tegra X1 Maxwell GPU Specifications:
    then lists the Maxwell gpu part as 20nm
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Well to be pedantic it actual says "Tegra X1 (Maxwell GPU)" With the Maxwell GPU part being in brackets so I would consider to mean the wording in the brackets are aside from the main point, that main point being the stats in the chart.
    Maybe someone else can clarify things as everything I've read says the Tegra X1 uses ARM Cortex A57 & A53 CPU built on 20nm, paired with a Maxwell 2 GPU built on 28nm, I'm no expect in SOC design so would be interested if your right and the Maxwell 2 GPU inside the Tegra X1 is indeed fabricated using 20nm.
  3. Harlequin
    Harlequin Modder
    4 Jun 2004
    whereas to me it would be incredibly inefficient to build one part of the SoC for 1 fab process and another part on a different process.
    imagine the cost of merging 1 SoC from 2 different wafers!
    I think you`ll find the whole lot is on a single wafer and its all 20nm ;)
  4. Corky42
    30 Oct 2012
    Well strictly speaking not many (if any) chips use a single node size, when we refer to AMD & Nvidia using 28nm that's only talking about the actual transistors, other parts of the chips may well be using a larger fabrication technique.
  5. loftie
    loftie Modder
    14 Feb 2009
    TBH, we're discussing the 390 and PC hardware. While I get that Nvidia may be at 20nm, does this really mean that they can produce a much higher power drawing PC part on a process designed for small, low power products. Probably not. The rumours for Pascal are 14nm, and while they are rumours, I've seen nothing about 20nm Pascal. I suppose only time will tell.
  6. Jamie Cortez
    Jamie Cortez What's a Dremel?
    15 Nov 2010
    Where did this come from?
    Is this actually legit info?
  7. Cei
    Cei pew pew pew
    22 Mar 2008
    Well that news is confusing.
    R9 Fury X ($649)
    R9 Fury ($549)
    R9 Nano
    R9 Fury Dual GPU
    The latter two are due summer and beyond, but all the Fury branded cards use HBM (4GB limit) and are apparently more power efficient (though AMD don't want to share numbers). The R9 300 series then seem to slot in underneath these cards, entirely made up of re-brands.
  8. loftie
    loftie Modder
    14 Feb 2009
    Probably from PCPer, Linus and the other one I can't remember, who threw a few twitter comments out about it. I believe Guru3D said that they will be getting one after the announcement/release. Seemed like a storm in a teacup mixed with sour grapes from the first 3 tbh, I've not heard any other sites confirm or deny they'll be getting one.
    @Cei They gave us a the Nano stating it was 2x perf/watt then saying it used half the power of the 290x - so think 970. And for the others, I'm fairly sure I caught 275W average for one of the Fury/ Fury X. I missed the 300 series part, so no idea what's going on there.
  9. Cei
    Cei pew pew pew
    22 Mar 2008
    I got 1.5x performance per watt, but hey, lets wait for the real numbers. It does look like it's aiming for the same market as the 970 Mini.
  10. loftie
    loftie Modder
    14 Feb 2009
    1.5x was the Fury/x , Nano hit 2x. Though what is weird is in the Video Dr Su actually mentions "significantly more performance than a 290x" with half the power and 2x perf/watt so who knows! Good stuff either way. I liked what I saw of Quantum too, looked rather interesting.
  11. Rotcrack
    Rotcrack Food Maestro.
    24 Jul 2009
  12. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    thats a small dual GPU card.
  13. Harlequin
    Harlequin Modder
    4 Jun 2004
  14. Corky42
    30 Oct 2012
    Yea, sorry to say I'm not willing to take his word as gospel on the subject, even if he is the senior editor at WCCFTech, his wording is ambiguous and it seems he's only repeating what the marketing blurb says.
    Maybe we should start a new thread as we seem to be taking this one a little OT. :blush:
