News AMD releases OpenCL SDK
Discussion in 'Article Discussion' started by Sifter3000, 7 Aug 2009.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    Woot awesome, cant wait to see what people come up with ^^
  3. Motoko
    Motoko What's a Dremel?
    8 Jul 2009
    Hopefully CoreAVC can use this to implement hardware acceleration for video files. fingers cross.
  4. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Why don't some smart programmers use the SDK to make it cuda compatible. Instead of rewriting the cuda apps to run an a ATI GPU?
  5. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    why don't some smart coders make an opensource version so things aren't split up between cuda and stream? isn't M$ doing something like that with Directx11
  6. Paradigm Shifter
    10 May 2006
    Would be neat if Stanford used this to make ATi GPUs more competitive in folding again.
    Also want a PC capable of upscaling as well as my PS3.
  7. KoenVdd
    KoenVdd What's a Dremel?
    6 Aug 2007
    Be carefull, this release still only supports OpenCL on the CPU. If you look at the "what's new" on the product page, it only mentions OpenCL for CPU, which is how other sites are reporting it.
  8. HourBeforeDawn
    26 Oct 2006
    well on the physics side of things, I know thats what MS is doing with DirectX 11 and same goes with OpenCL which will be nice as it will work with both manufactures.
  9. Chocobollz
    Chocobollz What's a Dremel?
    25 Dec 2008
    Or maybe nVidia should just throw CUDA out of the window and start supporting OpenCL or DX11 Compute Shader as a standard. That would make everyone's lifes easier (I think :p). On topic, I think this is a good move by AMD. They haven't get the market trust back again but at least they're on the right track now. Hopefully more and more peoples will consider to buy AMD's products again (including me :)
  10. Elton
    23 Jan 2009
    There's only one thing I'm still perplexed about....WHY ISN'T AMD improving steam?
    This is a good step though.
  11. HourBeforeDawn
    26 Oct 2006
    +1 on throwing out Cuda and PhysX for that matter
  12. Tim S
    Tim S OG
    8 Nov 2001
    Nvidia does support OpenCL - drivers are here: http://www.nvidia.com/object/cuda_opencl.html
  13. Tim S
    Tim S OG
    8 Nov 2001
    I happened to be away on compassionate leave on Friday and, as a result, a factual error crept into this article - I keep right up to speed on the latest developments in GPU technology and GPU computing, so I would have proofread or edited this article had I been at work. ATI Stream SDK 2.0 beta 2 does not support GPU acceleration in OpenCL, as was suggested in this article. I have written a supplementary article to this one, detailing AMD's plans for GPU-accelerated OpenCL support in Stream SDK: http://www.bit-tech.net/news/hardware/2009/08/10/ati-stream-sdk-v2b2-gpu-support/1
Tags: Add Tags
