News AMD Ryzen 3 5300G APU grabs trio of OC world records
Discussion in 'Article Discussion' started by bit-tech, 9 Aug 2021.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. arberda2
    arberda2 What's a Dremel?
    23 Aug 2021
    I don't understand their decision for "OEM only." For instance, I'm looking for an APU with powerful iGPU for emulation. Definitely not paying for the 5600G, it's overkill. The 5300G should be released for retail indeed.
  3. sandys
    sandys Multimodder
    26 Mar 2006
    Pretty much any APU will be fine for emulation, you can still buy OEM one if you really want one, I bought the 4300GE OEM and it is a monster compared to the older 3xxx chips even in 35w form, improved memory controller helps get memory speeds up for the on board GPU.
Tags: Add Tags
