Reviews AMD Ryzen 7 3800X Review
Discussion in 'Article Discussion' started by bit-tech, 10 Sep 2019.
  1. zx128k
    zx128k New Member
    8 Oct 2019
  2. zx128k
    zx128k New Member
    8 Oct 2019
    3dMark Fire Strike
    9900k @ 5GHz all cores fire strike
    RAM – Crucial DDR4 3000MHz Quad-Channel 32GB + Optane
    Average: 24417
    3800x stock cores 3600CL16 RAM Overclocked to 3800CL16 - Average 26036
    https://www.3dmark.com/fs/20577914
  3. zx128k
    zx128k New Member
    8 Oct 2019
    Gears of War 5
    Core i9 9900K
    Z390 (ASRock Tachi Ultimate)
    32 GB DDR4 3200 MHz CL16
    NVMe M.2. SSD WD Black
    https://www.guru3d.com/articles_pages/gears_of_war_5_pc_graphics_performance_benchmark_review,3.html
    1080p settings as per the website.
    2080 ti 135fps
    Titan Xp 120fps
    2080 super 119fps
    2080 111fps
    3800x and 2080.
    Average fps 123.5FPS
    GPU bound 99.90%
    CPU bound 0.10%
    This is an AMD sponsored title.
    See this video which shows a 9900k is CPU bound 10.09%. 24gb Ram / RTX 2080 OC 8gb / i9900k 5.0 GHZ I love the RAM amount.
  4. zx128k
    zx128k New Member
    8 Oct 2019
    METRO REDUX BENCHMARK RESULTS
    Source
    Results: Average Framerate: 192.96
    Max. Framerate: 349.41 (Frame: 27063)
    Min. Framerate: 33.52 (Frame: 8) Settings:
    Resolution: 1920x1080
    Quality: Very High
    SSAA: Off
    Texture filtering: AF 16X
    Motion Blur: Off
    Tesselation: Very High
    VSync: Off
    Advanced PhysX: On
    Test Bench:
    Intel 9900k Processor Overclocked to 5.0ghz All Cores No AVX Offset (1.27V)
    Corsair H150i PRO 47.3 CFM Liquid CPU Cooler (Fans @ 100%)
    Asus ROG STRIX Z390-E GAMING ATX LGA1151 Motherboard
    Corsair Dominator Platinum RGB 16 GB (2 x 8 GB) DDR4-3200 Memory
    Samsung 970 Evo 250 GB M.2-2280 SSD (Boot)
    Samsung 850 EVO 250 GB 2.5" SSD (Games)
    Asus ROG Strix RTX 2080 OC Edition (GPU Boost Clock @ 1970MHz)
    Corsair RMx 650W Power Supply
    Corsair 750D Airflow Edition Case
    Windows 10 Home Nvidia Driver 430.39
    Using 100% the same settings on my system.
    AMD Ryzen 7 3800x
    ASRock X570 Taichi
    NVIDIA GeForce RTX 2080
    Team Group Inc. 8192 MB (DDR4-2400) - XMP 2.0 - P/N: TEAMGROUP-UD4-3600
    Full custom water loop 360 rad and full copper block. push/pull fans.
    Corsair AX1000
    • Average Framerate: 204.17
    • Max. Framerate: 392.62
    • Min. Framerate: 35.17 (Frame: 8)
  5. zx128k
    zx128k New Member
    8 Oct 2019
    Metro Exodus
    Source
    Test Bench: Intel 9900k Processor Overclocked to 5.0ghz All Cores No AVX Offset (1.27V)
    Corsair Dominator Platinum RGB 16 GB (2 x 8 GB) DDR4-3200 Memory (16-18-18-36)
    M.2-2280 SSD (Boot)
    Corsair RMx 650W Power Supply Corsair 750D Airflow Edition Case
    Benchmark Tool. Results:
    Average Framerate (99th percentile): 64.45 Max.
    Framerate (99th percentile): 93.17 Min.
    Framerate (99th percentile): 38.37
    Settings: DirectX: DX12 Resolution: 1920x1080p Quality: Ultra Texture Filtering: AF 16X Motion Blur: Normal Tesselation: Full Advanced PhysX: On Hairworks: On Ray Trace: Ultra DLSS: Off Shading Rate: 100%
    AMD Ryzen 7 3800x
    ASRock X570 Taichi
    Corsair AX1000
    • Average Framerate (99th percentile): 65.30
    • Max. Framerate (99th percentile): 90.33
    • Min. Framerate (99th percentile): 38.14
    Options: Resolution: 1920 x 1080; DirectX: DirectX 12; Quality: Ultra; Texture filtering: AF 16X; Motion Blur: Normal; Tesselation: Full; Advanced PhysX: On; Ray Trace: Ultra; DLSS: Off; Hairworks: On; Shading Rate: 100;
  6. zx128k
    zx128k New Member
    8 Oct 2019
    My above 7 posts show that a correctly overclocked 3800x can give the 9900k a run for its money. That the 3800x could be as fast if not faster than many 9900k builds with all core 5GHz overclocks and decent of the shelf RAM kits. This is if you understand the weakness the 3800x has and why AMD recommends tightening RAM timings. The chiplet design increases RAM latency by 10ns. With the 3800x, overclocking is about fixing some of the bad RAM latency. Latency can be reduced from 75ns to 63-64ns average. The CPU itself is already fast enough. Overclocking is about the RAM on the 3800x.
    The source can be found on the forum overclocker co uk under cpu and the 3800x vs 9900k thread. threads/3800x-vs-9900k.18866559/page-8
Tags: Add Tags
