Reviews AMD Ryzen Threadripper 3970X and 3960X Review
Discussion in 'Article Discussion' started by bit-tech, 25 Nov 2019.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    That whooshing noise is the collective sigh of relief of developers everywhere who no longer face the prospect of being stuck with coding for multiple NUMA domains for desktop/workstation use.
  3. sandys
    sandys Multimodder
    26 Mar 2006
    It is a great upgrade on both the platform and the chip, a proper next generation, so much want! unfortunately not enough need :( :D
    Would have been interesting to see core boost scaling with processor thread load
  4. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    I've got absolutely no use for so many cores but i can't help thinking Phwoar when looking at these, i imagine if you've got a use for so many cores these are a boon.
  5. loftie
    loftie Multimodder
    14 Feb 2009
    You can spend lots of time looking at all the bars in task manager and going Phwoaaaar - hours of entertainment right there :D
    Isitari, MightyBenihana, jb0 and 3 others like this.
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Is that a smug little chuckle I can hear from a certain Dr. Su? Well deserved, Lisa.
  7. Corky42
    30 Oct 2012
    I don't think they would, they may want to game when they're not using it for work though.
  8. jb0
    jb0 Minimodder
    8 Apr 2012
    They'd do it for the ePeen.
  9. sandys
    sandys Multimodder
    26 Mar 2006
    Because you buy nice hardware to work on but when not working its playtime.
  10. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    So, I just need Bitcoin to climb before I can afford this.
    jb0 and MLyons like this.
  11. Vault-Tec
    30 Aug 2015
    Barbaric. Absolutely barbaric.
    The mind boggles at what the 64 core will be capable of.
  12. Corky42
    30 Oct 2012
    63 times more than what one core is capable of. ;)
    Sorry, i couldn't resist.
  13. Anfield
    Anfield Multimodder
    15 Jan 2010
    So is the price tag:
    3900x + mobo + ram approx £1k
    Intel HEDT + mobo + ram = £1.5 - £2k
    32 Core Ripper? Cpu + mobo + ram approx £3k....
  14. Vault-Tec
    30 Aug 2015
    I don't begrudge the prices at all. They're far cheaper than when we were under Intel's rule. You know? The same Intel charging £185 for a unlocked 2c 4t I3 before Ryzen came along.
  15. Anfield
    Anfield Multimodder
    15 Jan 2010
    If you actually need all those cores on a regular basis then yes the price is fine, but for the majority it just makes more sense to buy a "puny" CPU instead and spend the difference on a 2080TI or a couple SSDs.
  16. Vault-Tec
    30 Aug 2015
    Indeed. At least AMD have launched these CPUs. It's amazing how many Intel ES I've had that were never launched. Simply because Intel couldn't be arsed and didn't want to push things on quickly.
    Yeah the prices are crazy. But, so is the performance if you need it :)
  17. Christopher N. Lew
    23 Apr 2009
    When do the motherboard reviews come out?
  18. Vault-Tec
    30 Aug 2015
    OC3D has a couple.
  19. RedFlames
    23 Apr 2009
    OC3D has a couple up, IIRC GN has a couple up, and IIRC Guru3d said their would be up in the next day or so... one assumes Bit will be in the next day or so also.
  20. perplekks45
    9 May 2004
    "If you're not sure whether or not you need HEDT then you don't need it" somebody said. And was completely correct.
    Personally I have absolutely ZERO need for TR but damn I want one.
    Goatee likes this.
Tags: Add Tags
