Reviews AMD Ryzen Threadripper 3990X Review
Discussion in 'Article Discussion' started by bit-tech, 30 Apr 2020.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Now that was surprising. Or not.
    A great product IF you have a use case. Like so many HEDT chips, this one is a beast in any workload, but almost unbeatable when it comes to highly scaling workloads (i.e. rendering).
  3. Hustler
    Hustler Minimodder
    8 Aug 2005
    Good for AMD that they're actually respecting the £/$ exchange rate when it comes to pricing.
    ..a stark contrast to the other tech firms such as Corsair, Asus, Gigabyte and all the others, that like to rip off their UK customers with a totally unjustifiable £1=$1 (or worse) pricing structure.
  4. perplekks45
    9 May 2004
    He also said water is wet.
    It should come as no surprise to nobody that 64c/128t CPUs are niche, even for HEDT. There are hardly any use cases outside of professional customer circles that even get close to using that many threads. Whether or not this CPU blurs the line between HEDT/pro-sumer and professional even more? Sure, maybe. If you don't need that much memory bandwidth or total memory and can live with potentially higher TDP, this CPU might save you quite a bit of cash.
  5. David
    7 Apr 2009
    Niche is an understatement - there are few workloads that will see a benefit of this over 32c/64t. Still mind-blowing.
    That power consumption! :lol:
  6. Spraduke
    Spraduke Lurker
    23 Sep 2009
    We have a 3970x workstation at work and its absolute monster. But for not much more than the price of the 3990x we got a whole workstation (including a RTX2060). Even the 3970x exceeds the thread limit on some of the niche software we use. But there is something mental about seeing 64 threads running near full tilt and also seeing a single threaded application running full tilt use 'only' 3% of your CPU!
    You could add a heavy excel recalc workbook to the tests as this does seem to use 64 threads on the 3970x (but appreciate that's not the reason people are buying these).
    On a similar vein, have you considered adding some CFD or Finite element workloads to these workstation benchmarks? OpenFoam is freely available on the CFD side and I'm sure you could create a 'bit tech' benchmark without too much difficulty.
  7. wolfticket
    19 Apr 2008
    It's mad. I love it :happy:
  8. Vault-Tec
    30 Aug 2015
    That is because the apps he uses don't support the core loads. So for now it would be a waste of money.
    If you are Pixar however? go for it.
    These are designed for a specific purpose, and it isn't us. That said they are an engineering marvel. Sheer silicon pron. So fair play to AMD.
  9. DbD
    DbD Minimodder
    13 Dec 2007
    It only supports 4 memory channels so the effective memory bandwidth available to each core is tiny. The moment you go beyond the cache all those cores will be just sitting around waiting for memory. That makes it's usage pretty limited. It's got to be something not suitable for a gpu (which has many more cores and much high memory bandwidth) and needs only a few mb of memory.
  10. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    One is with tax and one is not... So actually the UK price is very cheap
  11. jb0
    jb0 Minimodder
    8 Apr 2012
    In most areas of the US, sales tax is much lower than the UK's VAT. The highest points in the US look to be about 12%. So it depends.
  12. djlegend
    djlegend What's a Dremel?
    9 Jun 2015
    The AMD Ryzen Threadripper 3990X CPU is present in my system. To date I am very satisfied with the performance.
Tags: Add Tags
