News AMD shipping Llano in April, says industry analyst
Discussion in 'Article Discussion' started by arcticstoat, 24 Mar 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. NethLyn
    NethLyn Minimodder
    24 Apr 2009
    The Sandy Bridge window of opportunity's gone and retailers have been dropping prices on AM3 stuff to make way - I've gone from AM2+ to AM3, the backbone with just an Athlon II coming in under £120 and still with the full range of the other CPUs where prices will only fall further as upgrade options.
    They should release the latter parts sooner as well for the health of the company, they need revenue back from the bread and butter, not just graphics cards.
  3. Platinum
    Platinum What's a Dremel?
    25 Jun 2001
    Half tempted to get one of these, as I understand it you can get a add in GPU and use hybrid crossfire between the two.
    A A6-3550 Quad core with 400 shaders paired with say a Saphire 5670 Ultimate should make for a awesome medai / lan pc thats pretty much silent.
  4. Narishma
    Narishma What's a Dremel?
    21 Feb 2008
    Bulldozer isn't an APU, is it?
  5. Ninja_182
    Ninja_182 Enginerd!
    2 Apr 2002
    Just out of interest is this the double L at the start a long L or a Welsh double L? I cant wait for the video interviews if it's the latter.
  6. sWW
    sWW Minimodder
    3 Apr 2010
    Are the graphics chips on these supposed to be better than those found on Sandy Bridge procs?
  7. frontline
    frontline Punish Your Machine
    24 Jun 2007
  8. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    cant wait ^_^
  9. Unknownsock
    Unknownsock What's a Dremel?
    13 Jul 2009
    Really wish they gave out for info, as i was waiting for Llano or Bullzdozer for my next build but SB came first..
  10. REMF
    REMF What's a Dremel?
    31 Mar 2009
    the dual core with 160 shaders seems like a winner to me, should have a TDP of 25W which will it to be used in slimline 11.6" chassis's.
    i want.
  11. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    In terms of gaming performance, easily better.
    The GPU inside Llano is essentially a HD5650 mobility which easily trounces the HD3000 found in any mobile Sandybridge part (the latter being slightly quicker than a HD5450m). Expect playable performance @ 720p and medium settings is most up to date games. Not bad really.
    EDIT: Sorry the above is for the 400SP part found in the Quad core models. The Dual core's 160SP part should still perform better than the HD3000 although they will be close. I would give the nod to AMD simply due to better / more up-to-date driver support.
Tags: Add Tags
