News AMD unveils Ryzen Threadripper retail packaging
Discussion in 'Article Discussion' started by bit-tech, 25 Jul 2017.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. sandys
    sandys Multimodder
    26 Mar 2006
    Everytime an article is linked in the forum the hyperlink does not work for me because it contains an extra / in the http bit, perhaps one of the scripts is a bit dodgy?
  3. yuusou
    yuusou Multimodder
    5 Nov 2006
    Fixed that for ya.
  4. Gareth Halfacree
    4 Dec 2007
    I'm not seeing it here: the link from this 'ere forum thread is http://www.bit-tech.net/news/amd-unveils-ryzen-threadripper-retail-packaging/1/, with the correct number of slashes.
  5. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Maybe it's a browser thing as I've also been getting it.
    Code:
    [QUOTE="bit-tech, post: 4365418, member: 1"][URL='http://\www.bit-tech.net/news/amd-unveils-ryzen-threadripper-retail-packaging/1/']Read more[/URL][/QUOTE]
    I'm using a fork of FF (Pale Moon) if that helps.
  6. sandys
    sandys Multimodder
    26 Mar 2006
    I use IE11
  7. Gareth Halfacree
    4 Dec 2007
    I use Chrome, which is apparently smart enough to fix the problem: I can see an errant backslash if I inspect element, but if I click on the link (or even right-click and copy the link) it dun gon vanishes. S'worth reporting in the bug thread, I'd say.
  8. sandys
    sandys Multimodder
    26 Mar 2006
  9. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    I'm aware it shows that in inspect element but the link is still functional right?
  10. davido_labido
    davido_labido Your Alphacool Contact.
    11 Oct 2013
    Can confirm, this doesn't work on Pale Moon. Every other browser I have tried works fine though.
  11. MLyons
    3 Mar 2017
  12. David
    7 Apr 2009
    Woohoo, a box. :eyebrow:
  13. davido_labido
    11 Oct 2013
    I have just tried it on Summer Moon and it seems to be fine :oldconfused::duh::eyebrow:
    MLyons likes this.
  14. MLyons
    3 Mar 2017
    Can you send me a gif or something of this happening. I've tried this in IE 5 - 11, Edge, FireFox, Chrome, Safari, Ie XBOX360, IE XBOX One and Bing bot and can't recreate it. The only way we could get it to happen is downloading "Pale Moon" which means I'm not going to look into it as it seems to be isolated to one obscure browser. If someone can get me a gif of video of some kind along with details of this happening in a modern (even IE8) browser then I'll happily look into it.
  15. Gareth Halfacree
    4 Dec 2007
    Replicated first try using IE9 via Browserling.com:
    (I'd try other versions of IE, but Browserling.com will only let you use IE9 unless you pay and nuts to that!)
  16. MLyons
    3 Mar 2017
    Well then. I just tested this in a real IE11 browser and it works fine for me but fails on that site so not sure what to think of that. This is looking like a real wonky issue. I'll see if i can work some magic n the back end.
  17. Gareth Halfacree
    4 Dec 2007
    All it needs is that errant backslash removing. That's the entire heart of the problem: as I said in t'other thread, some browsers know it's wrong and delete it thus work fine while other browsers know it's wrong and assume you meant to put a forward slash thus break completely.
    Get rid of the errant backslash (and stick an 's' on the end of 'http' while you're in there) and all will be well across all browsers ever.
    Stick the post-generation script up on a file share somewhere and I'll gladly fix it m'self and return it for your approval, if you like.
  18. RedFlames
    23 Apr 2009
    fwiw... links wfm in Edge, Chrome [dev channel] and Firefox ESR
  19. MLyons
    3 Mar 2017
    the issue with the script atm is the way browsers and xenforo escape characters. I think I've got a fix ready but wan't to wait until the forums and site are a little more quite before we test them out.
  20. Gareth Halfacree
    4 Dec 2007
    Aye, you've got an extra escape character that shouldn't be there would be my bet. S'always a pain when you've got things that need escaping and end up typing http:\/\/\ instead of http:\/\/ - s'not a mistake that readily jumps out at you on a quick visual check!
Tags: Add Tags
