TVs amd vs inte gaming rig
Discussion in 'Hardware' started by grritsshawn, 15 Jun 2009.
  1. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    Okay well im gunna be building a gaming rig that can play crysis mostly on all high settings
    i have about 700-900 to spend on it.
    Here is the question
    Should i use intel or amd
    I will no be overclocking anything
    what parts should i use?
  2. Jipa
    5 Feb 2004
  3. grritsshawn
    20 Apr 2009
  4. Jipa
    5 Feb 2004
    Both get the job done. S775 is already obsolete, i7 is still too expensive, and AM3 is... Well, pretty new. In that sense it might be a good idea to go for AMD, but then again, does anyone ever update just the processor?
    And seeing you aren't going to overclock, you might as well just toss a coin.
  5. grritsshawn
    20 Apr 2009
    im not sure to go all out or na
  6. grritsshawn
    20 Apr 2009
    Well i have decided if im gunna do it im gunna do it right and maybe will try to oc but not alot
  7. docodine
    docodine killed a guy once
    10 Feb 2007
