Scratch Build – In Progress AMPC (8/3 Final pictures)
Discussion in 'Project Logs' started by quizz_kid, 11 Feb 2015.
  1. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Hi guys
    Time for another wooden build of mine. The build is titled AMPC, as in amp+pc. AMPC is a smaller gaming rig hiding inside a case inspired by retro amps. My goal with the build is to visually hide all common PC attributes, to mimic a minimalistic amp. To have you all fooled that is! So don't expect any USB's on the front panel.
    I'm going to use walnut and aluminium for materials, and will start building around measurements of an amp for standard racks, 43.5, 16.5, 33 cm
    If interested in my work, please visit my official facebook page
    PC-specs:
    Sapphire PURE Platinum H61
    Intel i5
    Asus GTX 750TI
    Corsair RM650
    Corsair Force 256GB
    Corsair H75
    Corsair Dominators 4x2GB
    Others:
    Slot-in-DVD
    Arduino Leonardo
    I want to thank Inet.se for the GPU
    And also Johan at Corsair for these yummy parts
    Inspiration pic
    Analog meters and an Arduino Leonardo board
    Cheap China USB-slot-in-DVD
    12mm sheets veneered and cut
    Used a laser for ventilation, but it didnt got all the way through and I had to remove some material from behind
    Pieces ready for gluing
    But before gluing, I mounted these fat springback drawer slides. A nice detail for future upgrading etc.
    Gluing under pressure
    12mm pieces for inner chassis, with some cut tracks for the bottom piece
    I stained the inner parts darker for a nice contrast
    Gluing again
    This is my mean (!) ghetto router table, constructed from junkyard parts.
    Removed some material for the slides
    And here's the front panel, in brushed alu. Im real happy with the design. A bit costy when you dont have access to a CNC yourself. Worth it though!
    //Quizz
  2. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    Great minds think alike. I'm just planning a HTPC with an Arduino driven analogue meter (the old one is starting to develop issues in the PSU and frankly it can't keep up with HD video).
  3. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Hell yes!! SUBBED!
  4. stealth80
    stealth80 Minimodder
    1 Feb 2015
    threads like this make me think I should have taken a job involving wood work rather than sheet metal, looking good !
  5. Hzza
    Hzza Minimodder
    15 Apr 2013
    Oooo, subbed for sure. I've loved your previous logs.
  6. storm-83
    storm-83 Minimodder
    7 Nov 2014
    like the idea very much!
    consider me subbed
  7. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    A new Quizz project? How do you keep it going man, you never seem to stop.
    This looks like it's going to be another good one. What am I saying? You're always good man.
  8. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    So they seem!
    Looking forward to that HTPC build of yours... But finish what you've started first =)
    Thanks!
    Thanks!
    Thanks!
    Looks of an amp + functions of a PC... Simple as that!
    Thank you!
    Thanks Wisdom! Well, I just do what I want to do 247... Building stuff that is!
    Update
    Two layers of teak oil is all I need for the finish, don't want it too shiny
    Some 35mm alu round bar slices ready for turning
    45's
    Hole for screw
    A set of alu feet finished
    Mounting
    Looks good IMO
    Another angle
    MB and cooling installed
    A sort of fragile front bezel is glued onto the inner chassis. This is for lighting, but more about that later.
    A small gpu plate, laser cut
    This is the 650 PSU. I wanted to mount my SSD on to of it, but there are no options here...
    Unless you take it apart... And remove the PCB screws...
    ... and replace them with longer ones. TADA! Now you got yourself a mounting system.
    PSU mounted from bottom.
    Laser cut SSD plate for two disks
    I just got one for the moment, here installed with black stand offs
    This is how it looks mounted on top of the PSU
    Another angle... Quite happy with the solution
    Started on some dial knobs for the front panel. My lathe parting tool is in bad shape, so used a saw instead
    I wanted some separate the dials from the panel a bit, visually. Got the idea to use some black acrylic for a nice contrast, here glued with epoxy
    I love to insert half-ugly pieces into my lathe and make them... Fancy!!
    Drilled holes for the dial pots
    These three knobs will controll lighting later
    As you might have noticed, I will use a flex riser for the GPU card. This is how to make good looking standoffs when all you have is a lot of them short hex spacers. You just put some fancy clothes around them and...
    ... TADA!
  9. Cheapskate
    13 May 2007
    Awesome! :D That thing you did with the psu pcb screws is cheeky, and brilliant.
    There's a joke in there somewhere about how bad it is to get excited about someone working their knob... -Ah, I think I found it.
    Also, Holy cow! I got in before you finished this time!!!!:lol:
    Edit: ^That last bit should not be in the same post as the statement above it, but it's too late. I posted it.
  10. storm-83
    storm-83 Minimodder
    7 Nov 2014
    yes, aw, yes yes yes!
    *major sploosh*
    this is really looking nice
    //** EDIT **//
    650 watt seems absurdly overkill in this situation, no?!
  11. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
    wow.
    Wish I had the tools and skills to make something that looks even half as awesome as this!
  12. Nexxo
    23 Oct 2001
    Using the lathe for parting does indeed seem to be a dark art. A good indexable tool seems to give the most consistent results. The tool also needs to be absolutely squared up to the work piece, the saddle locked down and pressure applied at just the right RPM. It takes practice, I find.
    As for extended stand-offs, just make your own from some brass bar!
  13. hairyknacker
    hairyknacker Minimodder
    25 Jan 2012
    Q,
    Just luuurve your skills with the wid- absolutely second to none
    Giving me some ideas about something similar for a file server for my music collection maybe
  14. faxiij
    faxiij Minimodder
    25 Jan 2011
    It really freaks me out how seeing a new thread of yours gets me into some weird state of arousal.
    Not far from becoming my main source of inspiration - really awesome builds, all quite innovative in some way or another. Subbed for sure.
  15. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanks Cheaps!
    Thank you
    Overkill maybe, I had another GPU in mind from the beginning. Never hurts to have some POWER though =)
    Thank you!
    Ive got a new parting tool ordered. But yeah, it's tricky parting sometimes, especially with these small china lathes.
    Thank you!
    Thank you for those very kind words faxiij!
  16. morgansk
    morgansk I've got wood
    12 Jan 2013
    Yay, another Quiz build, and it's looking beautiful as usual. The front Aluminium piece is gorgeous! Can't wait to see more...
  17. noobas4urus
    noobas4urus What's a Dremel?
    7 Oct 2014
    Awesome work, very fresh and clean, you have a great touch.
  18. storm-83
    storm-83 Minimodder
    7 Nov 2014
    Well, i should know
    bought a 1000w psu because i got it dirt cheap
    had sli 660ti running off of it :duh:
    now that one card has died on me, i'm stuck with 3570k and a 660ti on 1kw, talk about headroom :rolleyes:
  19. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
  20. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thank you Morgansk!
    Thanks noobas4urus
    :naughty::naughty::naughty:
    Small update, but almost finished now
    Made a small front panel extension for audio out
    A little bit of soldering for the arduino module
    Probably the shortest power extension I've made so far...
    I lasercut a new design for the analog meters on three types of wood veneer; walnut, cheery and ash
    I went for the one in the middle, cherry. Looks best IMO
    The front piece of acrylic and the screws/spacers keeps the veneer straight and in position.
    Some epoxy applied on the front panel for the meters
    With everything mounted onto the panel, I glued the panel onto the inner chassis. I had some issues getting it into position, but with a variety of different clamps, I finally managed.
    Next update will be final. Mounting the DVD-drive, some lighting, and final cable management.
    //Quizz
