Amusing error message
Discussion in 'General' started by loply, 16 Jun 2003.
  1. loply
    loply What's a Dremel?
    26 Dec 2002
  2. Green Soda
    Green Soda What's a Dremel?
    26 Dec 2002
    yeah, its an old joke...
  3. quack
    quack Minimodder
    6 Mar 2002
    It's actually pretty sensible, once you've fixed the error - press F1 to confirm. How else will the computer know you've plugged the keyboard back in? :p
  4. DeX
    DeX Mube Codder
    22 Jul 2002
    Pretty obvious what it means. Just as obvious as 'Press any key' anyway. :rolleyes:
  5. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    It pauses before it intialises the keyboard, if it just ran without the keyboard you might have to reboot before it would work. Seems a little silly first time you see it i guess.
  6. pranks7er
    pranks7er mange tout
    25 Dec 2002
    only keys ya need Ctrl +Alt +Delete
    1994 Bios i think u need and update!!!!!!
  7. quack
    quack Minimodder
    6 Mar 2002
    Of course you can always turn the "stop on error" for the keyboard off in the BIOS settings.
  8. relix
    relix Minimodder
    14 Nov 2001
    I thought you should never plug a PS/2 device in while the PC is running? :eyebrow:
    And that's probably a 486 or some old stuff then. You have to remember, after a while manufacturers stop updating the BIOS, very logical.
  9. ndtinker
    ndtinker Car Washoholic
    23 Sep 2002
    I've never heard that before..I do it all the time. Win98 and 2K didn't like it much, but WinXP lets you plug and unplug mice/keyboards from the PS/2 without any problems.
  10. pranks7er
    25 Dec 2002
    my ps/2 keyboard is always re plugged in wile comp is running your prob thinking of old serial connectors
  11. 273BeLow
    273BeLow What's a Dremel?
    13 Apr 2002
    while not as comic I laughed when I got this
    come on it's a M$ mouse! and it worked fine..
  12. DeX
    DeX Mube Codder
    22 Jul 2002
    Lol those messages means the manufacturer hasn't spent thousands on getting microsoft to test their drivers. Proof that MS doesn't even test it's own software! :p
  13. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    Even if there is a keyboard error, it doesn't have to mean that the keyboard isn't present. It could just be telling you that the left windows-key isn't working or something. Or maybe the num lock LED is broken.
  14. 273BeLow
    13 Apr 2002
    yea the fact was the drivers are built into XP so in essence.. XP isn't tested to see if it's compatible with.. well itself.
  15. ndtinker
    23 Sep 2002
    Here's one I got when I ticked off Media Player.
