Scratch Build – Complete ⭐ An Actual Toaster - Mini ITX build
Discussion in 'Project Logs' started by Flux, 11 Jul 2020.
  1. Flux
    Flux Minimodder
    11 Jul 2020
    The final parts are ready and populated. I am not sure how to manage the cables.
    I have printed clear brackets that clip to the toaster enclosure and will be screwed to the base of the cage.
    [​IMG] [​IMG]
  2. Cheapskate
    13 May 2007
    You can clip and re-solder the PSU cables shorter, and remove extras. That's about all you can do in a toaster.
    Now that I look at it, you should have opened the bottom up a lot more. This setup could hotbox the parts, (-the irony. :D )
  3. Flux
    Flux Minimodder
    11 Jul 2020
    The bottom is the motherboard, I won't get any air in through there. But you are right, I am also a little concerned about airflow. But then again, It is an I5 6500, the TDP is said to be 65W, but at 100% load it uses 39W. So I hope I can get away with that.
    I am thinking about upgrading my hardware anyway, at that point I might also modify the PSU. For now I will just have to cram all the cables in there.
  4. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    using some mesh underneath you'd be surprised how much air can come up around the board through pressure. It will also help cool a rear M.2 drive and the back of the CPU socket.
  5. Flux
    Flux Minimodder
    11 Jul 2020
    Oh, okay? Currently, the bottom is open anyway. So maybe I just put it on feet.
  6. Cheapskate
    13 May 2007
    Ducting with foam is a possibility too. Something to force one set of fans to pull air from outside instead of swishing the air inside around.
    -Sorry, man. We like to overthink things here. I had to figure out how to keep something in a metal can like this cool too.
    We're loving the hell out of your project, otherwise there wouldn't be so much back-seat driving going on. :D
    MLyons likes this.
  7. Flux
    Flux Minimodder
    11 Jul 2020
    That's cool! I have tried running it with the enclosure for a while and I had no problems with thermals at all. I will revisit that problem with a future upgrade.
    Jean R built likes this.
  8. Flux
    Flux Minimodder
    11 Jul 2020
    It is finished (for now)!
    More pictures coming soon.
  9. enbydee
    enbydee Minimodder
    10 Jul 2014
    Amazing.
    Get me the marmalade.
    Flux likes this.
  10. MaximumBubbleMods
    MaximumBubbleMods Minimodder
    22 Apr 2020
    That orange glow really takes this to another level! :hehe: I love it man, nice work!
    Flux and kim like this.
  11. kim
    kim hardware addict
    10 Jan 2016
    Wow, fantastic result, it was quick as toasting slices of bread :grin:, looks like everything has been carefully planned from the get go :clap:, awesome :thumb:
    Flux likes this.
  12. Flux
    Flux Minimodder
    11 Jul 2020
    Thank you! At the time of my first post, I have already been past the worst mistakes. :)
  13. Flux
    Flux Minimodder
    11 Jul 2020
    Here is a video about it:
    [​IMG] [​IMG] [​IMG] [​IMG]
    TaRkA DaHl, lowfat, BHB Mods and 7 others like this.
  14. Jean R built
    Jean R built Modder
    17 Feb 2020
    It does have the look of a toaster, so mission accomplished, it must be fun to see the look of surprise of someone's face who see it for the first time :hehe:.
    It's a smile catcher, good work :thumb:.
    Flux likes this.
  15. Cheapskate
    13 May 2007
    Ah. I missed the exhaust fan. That should help. :D
    It came out extra fantastic. I think you will get in mod of the year competition, easy. -If... :worried: we get one this year.
    Flux, Defyant Mods and Dot_Kappa like this.
  16. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Gotta agree looks amazing :rock:
    Flux likes this.
  17. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    The coolest pc-toaster :grin:
    The glowing effect is ver nice :cooldude:
    Nowadays it' hard to find an optical drive in a pc.... but you place two! :lol: +1 rep for you
    Flux likes this.
  18. 4LIEN
    4LIEN Modder
    4 Jan 2020
    Very good work i really like the final result!
    Flux likes this.
  19. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Congratulation that is a fantastic mod. :clap:
    Flux likes this.
  20. Flux
    Flux Minimodder
    11 Jul 2020
    Thank you all very much!
