Disaster An easy CAD soft for making some plans for a cnc router?
Discussion in 'Modding' started by Dead Ghost, 13 Jan 2008.
  1. Dead Ghost
    Dead Ghost What's a Dremel?
    11 May 2007
    I found a local shop that does cnc cutting, but they need me to do a cad drawing of the panel. I wish to do something like this, from 2mm alu sheet: http://img233.imageshack.us/my.php?image=20406364ds7.jpg
    What CAD program is easier to use, for the job i need? Any CAD program is compatible to a CNC machine?
    Thank you in advance.
  2. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    Im not sure but cant you save images from photoshop cs2 as CAD
  3. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    can you just make a dimensioned drawing for them, rather then in a cad format? Even with something not meant for drafting, you could still make a decent drawing.
  4. marcus000
    marcus000 Watercooling Mad
    7 Aug 2007
    Sketchup can export to CAD but it doesnt handle curves very well..
    For all my CAD work like fan grills and rad grills I just use Illustrator along with its snap function. :)
  5. Cheapskate
    13 May 2007
    What kind of file formats can they import? Vector-based drawing programs and even Photoshop's 'work paths' can be exported to .EPS
    I would be interested in a fully-functional autocad freeware too. Those kind of things are becoming so rare anymore.:(
  6. Sleepstreamer
    Sleepstreamer I modded christmas!
    23 Jul 2006
    Sketchup is pure crap when it comes to this. Use either Autocad or my personal favorite, Rhinoceros 3D (There are others of course). You should save the file as a DXF. I'm pretty sure they'll prepare the file in a PC based CNC control application before they send it to the machine itself. Or if you'd like you could probably make a sketch on paper with all the required measurements. Just make sure you get all the measurements in mm
  7. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Autodesk AutoCAD would most likely be the best/easyest
    You could always draft it youself using a drafting board, paper, pencil and a T-square and have someone at the shop draw it in they're CNC machine
  8. kerbeh
    kerbeh What's a Dremel?
    23 Sep 2007
    arhemidies (sp?) and cadSTD are my two favourite free or freeish cad programs, For just something like that you can use an online image to vector program and that should be enough for most cnc machines, even from their importing a vector into a cad cam program is rather trivial.
