An interesting problem
Discussion in 'Tech Support' started by Bluephoenix, 10 Mar 2008.
  1. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    not so much of an immediate problem as a puzzling question.
    On my laptop, when I attempt to do a windows update, I have 14 updates that supposedly succeed in updating, but constantly show up as available updates.
    heres the list by KB#
    KB944533
    KB941568
    KB941569
    KB942624
    KB943055
    KB943078
    KB946026
    KB946456
    KB935509
    KB943411
    KB947172
    KB905866
    KB943302
    KB943899
    dates are 1/22/08, 12/11/07, and 2/12/08
    OS is Windows Vista Ultimate
    Hardware is a Sony Vaio VGN-FZ190
    hopefully someone has a solution, as everything I've tried has not worked (yet!!)
  2. ryanjleng
    ryanjleng ...
    15 Nov 2007
    try downloading each setup/installer file.
    install one and reboot. check windows update again to seeif that one was removed from list.
    good luck. :)
  3. Bluephoenix
    3 Dec 2006
    I've tried each individually, with the same results.
    Microsoft was singularly unhelpful (uninstall every damn update and try again; didn't work either)
  4. ryanjleng
    ryanjleng ...
    15 Nov 2007
    what a pain. bummer.
    i got no concrete ideas. :grr:
    wild ideas to try
    [1] Try login into the default XP "Administrator" and do it there.
    [2] go into Safe Mode and do it there. I'm not sure updates can be done in safe mode. can't recall..
    [3] registry cleaner?
    when all else fails, reinstall windows.
    sorry couldn't be any more helpful.
    cheers.
  5. Bluephoenix
    3 Dec 2006
    its Vista actually not XP, and I've tried a few registry hacks, and reinstalling is out of the question (no disc for starters sine its an OEM install)
    I'm continuing to work on it and will fix it eventually (I checked and they have actually applied since the fixes are there) or just ignore them.
    mostly this thread exists for those who wish to explore the mystery. :geek:
  6. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    right click on the update in the win update window and choose "hide". (or was it "ignore"?)
    Should work in theory at least.
  7. Bluephoenix
    3 Dec 2006
    lol, good one and my current fix :)
