Cooling And I thought my NH-D14 was big!
Discussion in 'Hardware' started by Phalanx, 1 Mar 2011.
  1. azazel1024
    azazel1024 What's a Dremel?
    3 Jun 2010
    I think someone just yanked the radiator off a motorbike
    Frankly other than to show off what is the point? The larger the radiator the more the diminishing returns. The only way to really increase cooling a lot, once a certain size of radiator is reached, is to reduce the ambient temperature used for cooling, increase the contact patch where the heat transfer is occuring (which can't really be done with CPUs) or increase the thermal efficiency of the heat transfer (use something more efficient than a copper base, better than regular heat pipes, use water instead of heat pipes, etc).
    Its what kind of bothers me about the massive 1kg coolers with dual 140mm fans. All that extra work to maybe carry away heat 20-30% faster than a little 350g cooler and single 120mm fan. Seems to make more sense to just go with a water cooler at that point.
  2. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    obviously, this is a passive cooler.
    the fans are only there to provide lift so it doesnt wrench itself off the mobo :D
  3. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    lol... from the pics it looks like it would be in the way of fitting a vga card too...
  4. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    I can't see the right mounting bracket for my Atom CPU anywhere on those pics ?? :miffed:
    j_jay4 likes this.
  5. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    I could see the point of this being a passive cooler with the fans only powering up if it reaches a certain temperature.
  6. bigkingfun
    bigkingfun Tinkering addict
    27 Jul 2008
    Screw the cooler.
    What motherboard is that? dual pcie x16 goodness on mATX.
  7. Matticus
    Matticus ...
    23 Feb 2008
    Strap on 4 of these and you have a hovercraft. Awesome!
  8. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  9. Matticus
    Matticus ...
    23 Feb 2008
    Ok, ok. You win :) But for that price I would rather have the fast GT's.
  10. paisa666
    paisa666 I WILL END YOU!!!
    4 Mar 2009
    hmmm... LOL
  11. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
  12. j.col
    j.col Minimodder
    23 Dec 2010
    it looks crazy, but i doubt it will be that effective
  13. Skellig
    Skellig What's a Dremel?
    2 Mar 2011
    I'm happy with my D14, thanks :D
  14. TehKrak3n
    TehKrak3n What's a Dremel?
    19 Jan 2011
    now thats taking things to extremes ...
  15. nchhabs
    nchhabs www.twitch.tv/dracaXL
    20 Jan 2011
    I think the NZXT Phantom would suit it, if the heatsink + fans aren't wider than the case, but if not, the Phantom has a huge 200mm fan mesh hole on its side which would match up reasonably nicely.
  16. KidMod-Southpaw
    28 Sep 2010
    Strap on too many and you'll end up with this:
    I still don't want one, it's that much of an overkill it'll be more inefficient than an indoor cannabis farm- A.K.A my bedroom. :worried:
  17. KidMod-Southpaw
    28 Sep 2010
    Whatever the designers were on- I have it!
    (read above comment)
