Other Android app to remote access desktop
Discussion in 'Software' started by silk186, 24 May 2015.
  1. silk186
    silk186 Derp
    1 Dec 2014
    I'm looking for something that would let me control my desktop from my phone(s4)
  2. Tichinde
    Tichinde Minimodder
    1 Sep 2010
    Logitech Touchmouse or PCRemote should do the trick.
    Both are free, and while PCRemote has adverts it does do a load more than just mouse and keyboard iirc (been a while since I used it, just tend to get up and walk/crawl to the tv :) ).
  3. theshadow2001
    3 May 2012
    Microsoft have an Android rdp client
  4. creative
    creative 500rwhp
    23 May 2014
    local network or when your out and about.
    I use teamviewer on my mobile devices to control work/home/laptop when I am out and about.
  5. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    +1 on Teamviewer. I also use it on my Galaxy S4 to control multiple computers.
  6. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    3 options:
    1. teamviewer if you want to see the pc screen on your phone while displaying it on a different display
    2. Microsoft RDP app, it is smoother than teamviewer but will lock your monitor and requires a pro (or above) version of windows
    3. Remote mouse, works like teamviewer but you do not see the screen on your phone instead you have to look at the monitor for it (I use this with display screens in work)
  7. Qazax
    Qazax Fap fap fap
    20 Aug 2012
  8. GMC
    GMC Minimodder
    26 Jun 2010
    Nice. I'll be giving this a shot. Can it wake a machine from sleep?
  9. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    only if your network adaptor supports it, might need to turn on wake from lan in bios, can be a pain though if something continually pings your machine, waking it when you'd rather it wasn't.
  10. GMC
    GMC Minimodder
    26 Jun 2010
    Yeah, and when you set it up it advises disabling sleep.
    A brief test today and you can connect when it is at the windows user login page so I guess I'll just need to ask the missus to switch on whichever machine I need to connect to.
