Rant Android Owners: Hear my Cries
Discussion in 'General' started by Gunsmith, 15 Jan 2011.
  1. b0ng0
    b0ng0 Reddomitlum
    26 Oct 2009
    No, but if you go into Phone Information -> Battery then see what's been using the battery the most that should help you narrow it down. What ROM are you running?
  2. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    2.2.1
    Battery usage breaks down as :-
    64% Cell Standby (79% of the time with no signal)
    19% Display
    5% Locale
    5% Phone Idle
    3% Angry Birds
    2% Android OS
    2% Internet
  3. ufk
    ufk Licenced Fool
    3 Jan 2004
    Juice Defender from the Android Market improved my legends battery life by quite a lot, turning off the sync also helps considerably (Juice defender helps with this by allowing you to specify that the 3g connection is only active for x minutes an hour or when the screen is on etc)
  4. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    Baboon do you keep wifi on? If you are generally in wifi areas this will boost your juice life as wifi uses less power than polling the umts/gprs network.
  5. Da_Rude_Baboon
    28 Mar 2002
    Its off most of the time. I work in a basement so I don't get mobile reception at my desk and the WiFi uses http proxy which android still does not support so I have the WiFi turned off unless i'm at home. I use locale to change my settings between work and home.
  6. crazyg1zm0
    crazyg1zm0 Minimodder
    20 Feb 2007
    If i can recomend something... Try oxygen rom over leedroid I was going to use leedroid but someone showed me oxygen and i was hooked.
    But to any HTC desire users on O2... I had a hell of a time getting my Desire rooted..
    I ended up having to make a gold card... Simple enough if you know what to do.
    Install an unbranded version of 2.1 so i downgraded
    Then it was just a case of running unrevoked.
    Both the downgrade and the root were handled very easily with a couple of bits of software so are very very use friendly. the only complicated bit was the gold card creation but once i got to know what i was doing It took no time at all..
    If anyone wants to root the O2 branded desires running froyo 2.2 gimme a shout and will link the guides I used to do it.
