News Angelbird unveils PCIe SSD
Discussion in 'Article Discussion' started by CardJoe, 19 Oct 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    Good product, what I wonder though is if you can open up just any (or any Sandforce) SSD PCB and slap it in the slots - it looks like they use the same standard SATA power and data connections, but my gut tells me it's proprietory.
    The speeds are probably comparable to Raid, so given the extra cost it doesn't show value for money right now. One thing that could tip in its favour would be Trim support - any word on whether it has this?
  3. Floyd
    Floyd Wire Twister
    4 Dec 2008
    Very nice option. Too bad its still out of the price range of most for a general drive.
  4. digitaldave
    digitaldave What's a Dremel?
    30 Jan 2009
    angelbird >> i thought only the Taiwanese used rubbish names?
  5. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    I have to say, Angelbird Wings does sound more like a female sanitary product than a super-fast storage solution.
  6. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    Bird's Angel Delight anyone?
  7. Lance
    Lance Ender of discussions.
    6 May 2010
    LOL!
  8. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    I don't know what the product is worth but it's nice to see a company talking about compatibility with other OS than windows (especially Linux). BTW how can they talk about mac OS installation while I thought MAc was only meant to be installed on apple computer?
  9. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Doing that could yield a roving Angry Bird.
  10. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    Yes. If you can get rid of HDD cages in cases then there'll be better airflow and cooling. Plus you don't need to worry about saturating SATA 6gbps before the next standard comes out. PCIe slots have way more bandwith (x16 PCIe 2 anyone?)
  11. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Erm, because this drive can be installed on a Mac (specifically a Mac Pro).
  12. jamesislush
    jamesislush What's a Dremel?
    22 Feb 2010
    That's some blisteringly fast quoted speeds... Whether or not it lives up to those claims seems yet to be proved, but if it does, then I think the £885 pricetag is definitely justified. PCIe is definitely the way forward in my opinion; who needs a southbridge!? One concern though could be a possible lack of Trim on RAID setups or am I mistaken on that?
  13. bobwya
    bobwya Custom PC Migrant
    3 May 2009
    I've got one word for ya : "trim"??!!
  14. Chiller1
    Chiller1 Hybrid Level 10 building
    20 Sep 2010
  15. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    I'm not interested in SSD at all (whatever slot they wanna put it in) until the prices come down massively. I can live with my current boot times/load times quite easily and save myself hundreds of pounds in the process.
    1TB for £40
    240MB for £350 (ssd)
    Hmm...let me think.
    No speed boost is worth that price. None.
    But I am happy for everyone to buy them and increase demand. Will make them cheaper for me in the end. Keep going suckers!
  16. bigBADbenny
    bigBADbenny What's a Dremel?
    14 Sep 2011
    Re "trim?" - they're using SF SSD's that have built-in trim/GC.
    So whatever your OS, you're covered.
    Like to see it 4 up with SF2000 :)
    If your choice of SSD doesn't have that built in, running an app like Diglloyd Tools "Recondition SSD" (for OS X) would likely restore your write speeds.
    Apparently attached disks can also be individually partitioned...
    Thus possibility exists to very afford-ably attain decent R/W speeds with 4x HDD's attached (preferably hybrid), each with short stroked partitons for RAID0 and the rest RAID1.
    This product will also be great in a Thunderbolt PCIe box, once they're affordable...
    Waiting for more reviews to choose between the models on offer.
  17. mclean007
    22 May 2003
    Not so. The way a RAID controller works is to break the direct connection between the OS and the disk - the OS addresses blocks on a 'virtual' drive created by the RAID controller (hardware or software), and the controller maps those requests to physical blocks on the relevant disk. TRIM does not work with other RAID controllers which connect to off-the-shelf SATA SSDs, so there is no natural assumption that it will work with Angelbird's setup. I don't know for sure that TRIM doesn't work with Angelbird, but the mere fact that the underlying drive hardware supports TRIM doesn't mean that TRIM will work properly with the Angelbird device as a unit.
Tags: Add Tags
