News AngelEye Technologies Bay-Res Revision 2 at MODTHEBOX
Discussion in 'Article Discussion' started by GreatOldOne, 9 Sep 2003.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    MODTHEBOX! takes a look at the latest revision of the Bay-Res reservoir from AngelEye:
    "The Bay-Res Reservoir Revision 2 measures 19mm (L) x 15mm (W) x 4mm (H)and is designed to reside in a 5.25" bay. This form factor allows for an easy, diverse installation on almost any case without the need for modifications to be made. The Bay-Res Reservoir Revision 2 is constructed from 1/4" cast acrylic which has been joined together with a water tight seal and pressure-leak tested."
    More here
Tags: Add Tags
