Multi Anno 117
Discussion in 'Gaming' started by Gunsmith, 26 May 2025.
  1. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    Looks good, been a while since I've been excited for an Anno game, here's hoping they've learned from the problems that plagued 1800
  2. GeorgeStorm
    16 Dec 2008
    Seen a couple of videos for this and am very hyped for it, recently just started a new game on 1800 with my brother trying the new horizons(I think?) mod, what issues did you have with 1800?
  3. Gunsmith
    23 Sep 2005
    2205 whilst visually impressive dropped the ball and neutered the complexity, 1800 tried to add back the complexity but they confused it with tedium and instead balanced the game to punish every step you took by forcing you to take 2 back to artificially lengthen the game.
    the artisen/engeer hump was the fun killer forcing major side stepping; the "off island" (where your forced to develop a whole new island to harvest non native resources) came far too late in tier 3 (artisan) while in 1404 and 2070 it was early tier 2, there's often a second "off island" that lands usually mid tier 4 but in 1800 it lands slap at the start of Tier 4 (engineers) with electricity forcing you to essentially start from scratch on another island if you didn't have native oil resources and if you did have oil on your starter island the sheer amount of steel you need to build it and tier 4 housing meant you need to build more steel mills but then you run into the problem of not having the population to run them, hooking them into the grid doesn't work because you to need double the input of iron and coal and building extra pop doesn't help because royal taxes **** you for anything more then 1000 of each pop class. Try to pre plan your island beforehand and royal taxes start to kill you and shipping people in via the pier comes too late at tier 4 as the costs to do so kill your income. its as if it doesn't matter how you try to attack the model it forces you to essentially spend your time tediously building nothing but tier 1 and 2 islands.
    it would have been easier if industrial revolution that came with tier 4 engineers could be developed to retrofit previous tier production to be more efficient when it came to workforce but that **** was was sold off as the BRIGHT HARVEST DLC and even then only worked with non field production in tier 2, if you wanted to bolster fields then **** you, its only available from tier 4 and you need ****ing oil. :wallbash:
    the whole game was balanced arse about face and rather then try fix it they just keep shitting out more DLC adding even more aerodynamic drag to a game with a boot full of lead.
    /rant
  4. GeorgeStorm
    16 Dec 2008
    2205 is the one newer anno I've never played (I think they removed multiplayer which is what I enjoyed doing with my brother so never tried it) so can't comment on that, and it's been a while since I've played 1800 with no dlc, but played a couple of games with my brother a decent way into it, each time adding a dlc or two, most recently adding land of lions and this mod so there's always plenty of 'new' stuff.
    Haven't played 1404/2070 for a while so I guess I don't find it as jarring going from needing to go to that 2nd island early for spice in 1404 vs probably red peppers in 1800, always remember finding it slightly annoying how early you needed a 2nd island to be fair!
    I don't think I've ever actually worked out what royal taxes are, just part of the general costs, but I do agree electricity throws a massive spanner in the works suddenly needing space for railways etc, never remember to even try to plan for it. Almost always play on fairly easy settings as we like to have a fairly chill time playing so maybe that's it.
    Either way I'm happy to keep playing until this comes out and then maybe we'll start a new game when it does!
  5. Gunsmith
    23 Sep 2005
    getting a second island in early imo is better as it often eases production later on, for 1800 my best starting strategy before flipping the table at the arty/engineer hump was to build 2 supporting islands first before starting the main, tier 1 being self sufficient so long as there's a potato fertility on both with one island focusing on "no T2 fert" early production (sausages, soap) with the other working on "T2 fert" (needs common starter island wheat/barley and hops fertility) production (bread, booze) with both island shipping the run off excess over to the other, both islands would be built to 1000/1000 t1 and t2 residents to dodge royal taxes and by having each island focus on half of T2's production chains it frees up workforce for flexibility to build whatever you need going forward depending on the fertilities of those starter islands, once they're full id build a little more of each t2 production to create more overspill on production before shipping both sets of trickle down run off onto a main island that had red peppers, the rest is then just a slog to end game.
  6. Gunsmith
    23 Sep 2005
    Release date is down for 13/11/25
  7. GeorgeStorm
    16 Dec 2008
    Anyone playing it yet? Played it for a couple of hours over the weekend, just a bit of the campaign solo as my game instantly crashed to desktop when I tried to invite my brother to a multiplayer game so hopefully that will stop happening asap.
  8. sandys
    sandys Multimodder
    26 Mar 2006
    Yup I have put in a few hours, I am liking it so far but not got very deep into it just campaign for now, only just started on Albion so I am abit slow, barely scratched the surface of trade route, research trees or levels of my people but I have been trying to adapt to controller :eek: so I can sit back and chill on it on my travels where it'd be easy to sink hours into it on a dual shock, so probably done more faffing with settings than anything, engine seems good, scales well, looks reasonable and plays well on an iGPU admittedly low framerates but they are acceptable in this type of game, though the benchmark gives the impression of a stuttery mess even on a 5080 with a 9950x3d never mind an Intel iGPU.
    Not experienced any crashes mind.
  9. GeorgeStorm
    16 Dec 2008
    Not really had any issues actually playing, other than seemingly sometimes clicks don't seem to register, sometimes have to adjust camera to then be able to place a building for example, but I did sometimes notice that in 1800 so may be a me issue.
    Performance wise seems good and agreed about the benchmark, had bits where it was saying 70fps but stuttering so looked really weird, but I'm playing it on a 7500f/7900xt and my brother on an older intel and gtx1660, opposite ends of the settings but no issues.
