Hello all. After installing SP2 (I think) this pop up window has started to come up when I try to connect to the internet/MSN Messenger even when I already am. It gets annoying as I need to to it every time I boot the PC up!! Oh, and another thing, is there a way to get the ADSL to boot up and connnect with the PC so I dont need to manually connect? Thanks in advance for all your help, Alex Here is a picture of the problem: http://www.spaceavenue.com/3/KAB8l71096572372.gif
You need to remove all the othe dial ups bar the one you actually use. And to get it to autostart, create a dialup shortcut and dump it in the start folder.
Deleted all of my connections and still the same screen: http://www.spaceavenue.com/3/ThX3B41096576771.gif
I dont think I can think of deleting SP2 as it makes the security window look good and I cant be bothered in future stopping downloads of it, please anyone any ideas?
SP2 is not spyware, it does not download itself. Disable automatic updating and then manually update.
