Modding Anodizing the chassi in blue
Discussion in 'Modding' started by Ra1n3, 17 Jun 2005.
  1. Ra1n3
    Ra1n3 What's a Dremel?
    3 Jun 2005
    Where can i get such anodizer?I want to anodize my case shassi in blue and i'm looking for some sites that are selling it.Is that a tape or paint?
  2. Firehed
    15 Feb 2004
    It's a very complicated and potentially dangerous process that needs to be done professionally. It involves, to the best of my knowledge, submerging the part to be anodized in a certain type of liquid while running a high electrical current through it so it can attract the powder (I think it's a powder). It rather acts like food dye for metal, but without the right equipment and knowledge of it (neither of which you have I'm guessing), it's not something for home.
    But you can get paint and just paint a case. Or really anything you want. But anodizing is something best left to the pros.
  3. jerb111
    jerb111 What's a Dremel?
    25 Oct 2004
  4. striker289
    striker289 What's a Dremel?
    22 Jan 2005
    they have spray paint that mimicks anodized metal. try that, its cheapers too.
  5. Tech-Daddy
    Tech-Daddy What's a Dremel?
    8 Oct 2003
    For painting the anodized "look" Duplicolor and Krylon have paints that mimic the anodized finish.
    I've used the Duplicolor Blue and Green, and the X-Metals purple.
    In my sig, if you look at blingGreen, that frame was done with the green metal, Blu-V was the blue, and Lupine was done with the purple (I have not done the internal frame yet).
    Hope this helps.
  6. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    Anodizing at home is not that difficult. You need to be careful when you're doing because it does involve acid but other than that it's not that dangerous. However if you don't know what you're doing it's hard to get a finish that looks good and will be durable it's best to find a different option.
  7. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    it would consider it difficult and dangerous much can go wrong your dealing with high current electricy caustic and acidic solutions and the chance for poisonous vapours. The intial outlay in price means that unless you plan on setting up a run or small production its usually cheaper to get it done someplace else by some one who already has the setup.
  8. Guest-2867
    Guest-2867 Guest
    Anodizing is no more dangerous than a simple electrolysis experiment you did in your gcse's, honestly, if your careful there is very little that can go wrong.
  9. Speed
    Speed I'm all you need!
    13 May 2004
    I agree, there is no point setting it up yourself when you can just as easily go get it done professionally. Where you know the finish will be good and last along time.
