Windows Another Excel plea for help.
Discussion in 'Software' started by Kronos, 29 Nov 2017.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    I have created a small monthly table for my partner to record daily oxygen saturation levels and pulse. It only occupies the first three columns, Date, oxygen level and pulse and I would just like to save that bit of the sheet, essentially Columns A,B,C and rows down to 34 rather than a whole sheet, A-Z and beyond and many many rows, this possible?
    Please keep things simple but detailed as I find Excel frustrating at best and a bloody annoyance at worst.
    Cheers.
  2. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    You can't save part of a sheet, but you could hide all of the columns and rows that you aren't using.
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    That would do, how do I do that?
    Tried to create this simple but neat table in word with even less success.
  4. veato
    veato I should be working
    15 Jan 2010
  5. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    If you want to hide all columns past column C, do the following:
    • Click on "D" (i.e. the heading for column D) - this should select the entirety of column D.
    • Hold down Ctrl and Shift, then press the right arrow - this should select the whole of all columns from D to whatever the last column in your sheet is (Column XFD in my version of Excel, yours may vary depending on the version).
    • With the columns selected, right-click on the heading for the last column, and select "Hide".
    You can do the same for rows past row 34, but replacing "columns" with "rows" and "right arrow" with "down arrow" :D
    GeorgeK likes this.
  6. Kronos
    Kronos Multimodder
    6 Nov 2009
    It certainly would, I have created something similar, except I have yet to figure out how to put all the months dates in without doing so individually. I know how to do it in Excel but not a word table.
    Here is my effort
    https://drive.google.com/open?id=1309KPNgc4l539Ypy37VAUi7rrrOIx0zU
  7. wolfticket
    19 Apr 2008
    What I'd probably do from the start is create the table in Excel and then copy-paste it into word.
    Alternatively you could just create an appropriate column of dates in excel and copy-paste them into your existing table in word.
  8. Kronos
    Kronos Multimodder
    6 Nov 2009
    Both look very interesting and I am away to try them as i have just put in a months dates manually and that is quite tedious. Thanks.
  9. GeorgeK
    18 Sep 2010
    100% this
  10. Kronos
    Kronos Multimodder
    6 Nov 2009
    Perfect though I have managed to create something with Word. But I will also play with as it is far easier to add a months worth of dates. Thanks.
  11. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    Excel version
    In addition to hiding unused columns and rows I have:
    • Sized the columns and rows to print to a single A4 sheet.
    • Hidden the Heading and Formula bar, these can be turned back on from under the View Tab, Show, Heading and Formula Bar.
  12. Kronos
    Kronos Multimodder
    6 Nov 2009
    Lovely but I would still need to add the days individually. But thanks for going to the trouble, much appreciated.
    This is my effort. https://drive.google.com/file/d/1gBBi4Lvxmcoer_-mj_aZf7EKkLbKI5JU/view?usp=sharing
