(Another) New system thread
Discussion in 'Hardware' started by rupbert, 7 Sep 2003.
  1. rupbert
    rupbert What's a Dremel?
    28 Jul 2002
    Hey peeps, just started a new job :) and first thing on my 'to buy' list was some new computer upgrades...
    Well after three hours of 'window shopping', my spending spree has grown from a graphics card and more memory, into a completely new system...
    Here are my chosen specsbelow, is there ANYTHING that seems out of place, will be a bottleneck etc?
    It's really a games machine, however the components do NOT need to be the highest available, just a decnt all-round system that will last me more the two years...
    128Mb ATI Radeon 9700 Pro DVI/TV DDR Retail £220.90
    120Gb Seagate Barracuda Serial ATA (ATA-150) (7200rpm, 8MB Cache) £93.41
    2.4GHz (PG-800FSB) Intel Pentium® 4 CPU 512k Cache £140.11
    Coolermaster WaveMaster TAC-T01 Aluminum Case £111
    550W CWT + SATA Quiet Dual Fan AMD/P4 App Active Fan Control Active PFC £65
    MSI 875PNEO-FIS2R 800fsb i875 Canterwood Chipset 2xGbit Lan DDDR400 SATA USB2 1394 5.1Ch Audio £149
    Creative Labs i-Trigue 2.1 L3450 Speakers £108.10
    17" LG 1710B TFT DVI Monitor 1280x1024 0.26mm £334.88
    Logitech Cordless Desktop Optical MX (Mouse & Keyboard) £78.73
    Corsair TwinX 512 MB 3200 CAS 2 ( 2 x 256MB PC3200 184 pin MATCHED PAIRCAS 2) £115
    All comes £1407 :)
    The only thing that really isn't essential is the TFT, as I already have a cracking samsung 17" syncmaster 700IFT...
    Ideally I would like a sata hardisk, and 4000 matched pair Corsair buts its well over £300 for 1024MB
    Opinions?
    Thx :)
  2. Guest-16
    Guest-16 Guest
    Nvidia TNT2
    Socket 7 mobo with a K6-2 cpu and AGP 2x port, also ISA slots are also good :thumb:
    4gig ATA33 harddisk is more then adequate
    Soundblaster AWE 64 isa.. mm nice
    2 point surround sound. Generic speakers.
    32meg PC66 dimms - lots of ram there, faster then EDO simms.
    Beige case.
    At least its unique :D :rock:
    bet u didnt expect that reply? eh?eh? :p
    Seriously..: Go for faster ram if you're gonna OC. Otherwise go for an AMD/nforce2 setup.
    Personally ive never heard of a CWT psu? and for 2.1 speakers arent they expensive?
    i875 boards are also expensive - i865PE should be just as fast and a lot cheaper. Unless you need the stuff on the MSI canterwood.
    I dont like the CM TAC "wave" cases either, but that's a personal opinion too.
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    Hear hear..
    For roughly the same cash you could get:
    Lian Li PC-601 or CoolerMaster ATC-201
    Both nicer cases...
  4. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    If you want to get the most out of any P4 800 processor, get the fastest RAM possible. PC4000 is rather nice ;)
  5. rupbert
    28 Jul 2002
    In terms of the case, I really wanted one that could hide the drive bays, which is why I choose the wave. The CoolerMaster ATCS-110 also has a door, but its £225 :eeek:
    I have a Lian-Li Pc60, but the beige drives look hideous...
    Think your right on the motherboard, I can save a lot by getting the MSI 865PE-NEO2-LS i865 P4 DDR for only £88 :)
    Can the £300+ pricetag for the 1024MB Corsair really be justified? Is it THAT much better than 3200?
    And the 2.1 speakers are really because I do not have the room for anything bigger, I want the best sound quality possible...
  6. rupbert
    28 Jul 2002
    Better going for the Abit NF7-S (V2.0) - nForce2 -400FSB and an AMD XP chip?
  7. batsman
    batsman the quiet one
    14 Nov 2001
    If you want budget go for nforce 2, waiting for mine at the moment, if you have money to burn then P4 with 800fsb or opteron:D
  8. rupbert
    28 Jul 2002
    I am not really on a budget as such, I am just not willing to pay for 'the best money can buy' simply because its the most expensive...
    If the Corsair 4000 really is that good, I would buy it...
    And just want a good combination of motherboard/memory/CPU that work well with each other...
  9. Kameleon
    29 Apr 2003
    If you want P4, then to overclock it as much as possible your RAM, and to a lesser extent your motherboard, have to be as fast as possible. With an Athlon system, you need a good motherboard (Abit NF7, Asus A7N8X or Epox 8RDA+ and families) and PC3200 RAM, more isn't really necessary to get the most out of the chip, as they aren't multiplier locked.
  10. batsman
    14 Nov 2001
    twin moss & thermal take heatspreaders
  11. Tim S
    Tim S OG
    8 Nov 2001
    I have found twinmos to be not as good as I was expecting, it's not very easy to run super tight timings at very high fsb's :blah:
    if you have lots of £££ go for the Muskin PC3500 level II
  12. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    You listed the P4B, not the P4C. Anyone passing over a 800mhz FSB Pentium 4 over a 533mhz FSB one is quite "whack".
  13. rupbert
    28 Jul 2002
    But the difference in price is horendous
  14. Kameleon
    29 Apr 2003
    If £10 is horrendous I think you should cut down in a few other places :D
  15. rupbert
    28 Jul 2002
    ROFL /my bad
    Looking at the wrong price!!!
  16. rupbert
    28 Jul 2002
    Am I correct in thinking the 9800Pro only offers a performance increase of around 10-15% over the 9700Pro?
  17. Tim S
    Tim S OG
    8 Nov 2001
    you can convert a 9700Pro to a 9800Pro, if my memory serves me correctly ;)
