Windows Another Strange XP problem....
Discussion in 'Software' started by Tim S, 15 Nov 2001.
  1. Tim S
    Tim S OG
    8 Nov 2001
    Check this one out.....
    My main rig runs fine, at whatever speed, whether it be 1.54, 1.50, 1.4 (stock speed), or 1.2 (underclocked!!)... apart from when I play sound.... then XP just freezes up :confused:
    I dont get this problem in windows 2000 though, and thats my other OS... so I know its not a sound card problem... could it be drivers??? I've got a Creative SB Live! Player card, and Ive got the drivers from windows update.... do you think I should get the drivers from Creatives website, and see if they work any better...
    This one is a really intreging thing, and Im normally good at finding what the problem is when something goes wrong.... however this one has got me well and truely tied up... :rolleyes: :rolleyes:
    Any suggestions?? :eek:
    Biggie
  2. MrBadidea
    MrBadidea What's a Dremel?
    10 Nov 2001
    Hav u any network cards installed?
    When I first built my pooter, I had no network cards in, but when I bought one for my network at work, at put it in my main rig, everything was fine untill I had to reinstall, and the drivers for the network card were installed first - then every time windows 'Chinged' it buggerd up (But then again it is windows :S )
  3. Tim S
    Tim S OG
    8 Nov 2001
    I've sorted the probs I think, Ive had a heft evening searching Microsofts Knowledge base :rolleyes:
    It was to do with the Power Management in BIOS, as apparently windows XP likes to sort its own power management out :D
    Cheers
    Biggie :cool:
