Networks Another Talk Talk Issue...
Discussion in 'Hardware' started by piko, 14 Jul 2006.
  1. piko
    piko What's a Dremel?
    14 Jul 2006
    hi, im trying to help a mate of mine get his wireless network working So i wont be able to post any screen dumps...
    He connected to Talk TAlk Dial up a while back and has moved to Broadband now from TalkTalk (TT i will refer to it as), so TT sent over the modem and he connected it all up nicely and it worked as far as i know, then he bought a Netgear wireless router, and the position of his Desktop relative to his Phone point is essentially On differnet floors and areas in the house.
    So we thought, connect the router to the phone point and power, so the lights for DSL connection and Wireless are on ok, but obviously that does not autiomatically set up the TT configuration. So what i need are, specifically for the service so i can set it up on the netgear LAN config screen over the network is the
    - ISP's IP address
    - DNS Server addresses
    and any other relavent information you can provide.
    Thanks very much and if you can help then please post...
  2. DougEdey
    5 Jul 2005
    You don't need either of those, they should automatically be updated when you connect using your TT username and password.
  3. piko
    14 Jul 2006
    we thought that as well, unfortunately it hasnt done much at all automatically
  4. DougEdey
    5 Jul 2005
    Then I would suggest you contact Talk Talk customer services direct.
