Graphics Another upgrade question
Discussion in 'Hardware' started by Kronos, 25 Apr 2016.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    I have a bit of cash spar and wondered if a 980Ti is a decent upgrade from a reference 980?
  2. Guest-56605
    Guest-56605 Guest
    It is yes, however with the next gen of Pascal GPU's set for release in June(ish) you might want to wait - firstly IF Pascal is all it's cracked up to be in terms of performance and secondly the 9 series of cards will inevitably fall in price as they seek to clear existing stocks.
  3. David
    7 Apr 2009
    Huge potential to get stung, if Pascal does launch in June.
    I'd wait, TBH, Glen.
  4. Kronos
    Kronos Multimodder
    6 Nov 2009
    Good thinking guys, but of course by then I will be skint. Oh well.
  5. Vault-Tec
    30 Aug 2015
    My 2p. A 980ti will be a major upgrade. Not sure on what Pascal will offer but if it's anything like when Maxwell came out there may be a £100 or so price drop on 980ti performance. However, first of all that won't happen until late summer and secondly the price of Pascal will all depend on what AMD do. You may end up finding that after waiting all that time you are going to be paying the same £ per performance.
    Personally? at your res? I would get a 980ti now. I wouldn't, however, buy one new I would scout OCUK (which you should have access to) and buy a used one for £430 or so (the going rate).
  6. Kronos
    Kronos Multimodder
    6 Nov 2009
    Not sure I would want to spend that sort of cash on second hand.
  7. Vault-Tec
    30 Aug 2015
    I may have a Fury X coming up for sale soon if you are interested?
  8. Kronos
    Kronos Multimodder
    6 Nov 2009
    Doubt it as I think I would prefer to stick with Nvidia. Plus the 980Ti is the better card by my short bit of research, thanks for the offer though.
  9. Vault-Tec
    30 Aug 2015
    At your resolution it would be pretty much dead even but up to you :)
  10. Kronos
    Kronos Multimodder
    6 Nov 2009
    If I decide to buy the 980Ti it will probably be the Evga my question is will my custom white 980 backplate fit?
