Im about to purchase a new pump to replace my aquavia. My choices are the DD D-4 pump or the D-Tek CSP 750. The loop will be a Pump? > White water > Maze 4 Gpu > Custom HD cooler > reservor Now I was going to get the D4 but the CSP is half the price. The tubing is 1/2" ID. So what would be the best pump for this loop?
I'd go for the D4 or this: http://www.cooltechnica.com/Merchan...ROD&Product_Code=AQX-50Z-DC12&Category_Code=P Here's an interesting read about pumps: http://forums.procooling.com/vbb/showthread.php?t=10825
I've used both and really prefer the CSP750. MUCH quieter (barely audible vs quite loud IMO), electronic fan-style RPM monitoring at least on the newer ones
opps forgot to place the radiator in there. (goes after pump) So the CSP is powerfull enough to run this series? I can go with only one pump so dual CSP is out of the question. Need some more suggetions plz.
http://www.modthebox.com/review323_1.shtml Compares it right to the aqua via. Apparently not quite as much performance but still, very quiet and compact. And they definately got the older ones, the new ones are much higher quality and black with a kind of heatsink-ish body. Well at least mine is.
Don't get the CSP-750, there are a few threads at procooling.com about problems with it. Go with the D4 or the new DDC.
DDC is 3/8 fittings. That forum sounds like the cold cathlod scare thats been going around. Fire how long have you had your CSP pump for
But easily adapted. The CSP750 is 1/4NPT or BSPP (US or Euro sourced) but to further what's been said above CA systems, the current model is being withdrawn and replaced with this.
yes i know i could have an adaptor but i dont have the space for it. hmm if the new model doesnt come out soon im buying a D4.
