A case that big and only support for a 240mm? Antec have really, really fallen behind almost every other case manufacturer! You need some fresh blood, like a hire from Corsair, or even Bit Fenix.
Like - red and black. Size. Neatness. Don't like - the huge ANTEC logo on the front. Just a small square like the Corsair would have been enough.
I honestly don't like it, as strange as that sounds seeing as I have a 900D. I think it is trying to be the Antec version of the 900D, just without all the good points. Don't get me wrong there is one thing I do like and that is the front panel minus the Antec imprint and Red stripe. My thoughts on what could be changed. The hard drive cages in the main section of the case should be able to be completely removed, and also the 5.25" bays should be able to be taken out if required as well. I think the mid plate could be all mesh to allow for things like pump's and reservoirs to be mounted to it.
Pretty standard in fairness. If it is aimed at a enthusiast market then it needs support for rads and fans not 12 hard drives.
Woah, 12 drives, hadn't noticed, well counted up, thats alot. As mentioned by others, support for RADs and as by mrbungle, more fans! Can't have enough of those personally...well quiet ones.
I like the general look of this, but it looks a little too tall. It'd be near perfect if it sacrificed some height for a bit more depth.
