Modding Antec 300 Project Log/upgrades
Discussion in 'Modding' started by stefan442, 20 Mar 2011.
  1. stefan442
    stefan442 Minimodder
    14 Mar 2011
    Right, this isnt going to be nothing mental. I have an antec 300 case and im looking to make it a nice clean and tidy pc.
    My list of plans include;
    - paint exsisting fans white
    - remove covers from fans. (wondering if it will affect airflow)
    - colour scheme; probably black and white. Considering the case is mostly black, i would make inside white with various other bits white.
    - braid all cables. Black or white, or a mixture
    - White led's. Would go blue but im thinking a nice pure bright white would look superb
    - side mount hard drive with platter showing, build a see through case (big maybe this one)
    - mount the cover on the dvd drive to make it look like there isnt a dvd drive.
    - spray power supply white
    - cut a hole for power supply. Or keep as it is. 2 front 120mm pulling air in and have 2 120mm pushing air out, 1 on back and 1 up top.
    - Make a window for the side panel, benefit would be getting rid of the vent hole i dont use. Making for better air flow and dust prevention
    - general sound proofing and dust prevention
    If anyone has any tips or links to help me out i would be very grateful. Im wondering what spray to use, and where to get some nice cable sheath from also LEDs. Any suggestions?
    :thumb:
    stefan
  2. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    Hey
    Sounds like a nice and simple mod :)
    For advice on painting head over and take a look a the Mod Men case mod Episode 3 other than that can't beat Halford's for paint.
    Try MDPC for sleeving.
    Thanks
  3. Guest-23315
    Guest-23315 Guest
    Nice and simple, but effective mods. Great way to start.
    You forgot:
    Post log on bit-tech.
    Also...
  4. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    if you remove the fan housing the air will just get moved about and it will lose direction, looks good but I don't think the cooling efect will be anything but worse.
    You can get braided cable LEDS and pre braided cable extentions now from most online PC retailers. I bought an ATX extended red braided cable and two Mobo CPU 6pin cables from specialtech.co.uk
    Good luck with your mods
  5. stefan442
    14 Mar 2011
    spray paint :
    http://www.halfords.com/webapp/wcs/..._productId_724415_langId_-1_categoryId_165495
    http://www.halfords.com/webapp/wcs/..._productId_210069_langId_-1_categoryId_165495
    http://www.halfords.com/webapp/wcs/..._productId_210031_langId_-1_categoryId_165495
    Was wondering if anyone had any idea on how much white spray paint i would need to cover the inside of an antec 300?! Its not the cheapest stuff and i dont want to buy too much if i can help it.
    Black rivets :
    http://en.mdpc-x.com/mdpc-mounting/rivets/rivet-countersunk-head-black.htm
    black sleeve kit :
    http://en.mdpc-x.com/mdpc-sleeve/sleeve-kits-+-tools/sleeve-kits/mdpc-sleeve-kit.htm
    Quite expensive for the sleeve kit, can remember seeing a decent cheaper one somewhere but i need a proper good net hunt! maybe ebay can help me out!But that is something similar to what i will want.
    http://www.mnpctech.com/PC_Cable_Wire_Sleeving_Kit.html
    (a lot cheaper) I will probably end up ebaying the majority of this stuff. But its good to get some research done! Or this site :D http://www.kustompcs.co.uk/acatalog/info_2499.html
    http://www.kustompcs.co.uk/acatalog/Braided_Cables.html
    Has them very nice nzxt braided cables, i already have a couple so i will utilise these anyway! But id like the rest to look just as nice
    http://www.kustompcs.co.uk/acatalog/Window_Kits.html
    Not 100% on the side panel window as of yet! Id need to find a design rather than just having a square!
    Get paid in a couple of days so i will start ordering some stuff! woop
  6. djzic
    djzic Bokehlicious!
    8 Nov 2010
    The extensions and the other sleeve are crap compared to mdpc. Trust me on that one ;)
  7. stefan442
    14 Mar 2011
    Current state of my pc. I would like to remove the hard drive cage but it would mean that i would have a big job of hiding all the psu cables, i was thinking if i side mounted my hard drive then it could possibly act as a barrier to hide all the psu cables. I could drill out some nice big wholes and fill them with grommit strip! In fact, just drill a big ass hole and shove the cables through behind the mobo! Then drill individual holes for where they need to pop out! Length wont be a problem and i would only really need to sleeve the cables popping through. Unless i pro it and adjust lengths and sleeve all the way back to psu!
    I will pait all fans in a uniform colour, probably just paint the fan itself white and keep the casing black. Ill see how they come out, ive seen somewhere that you can just pull a clip out and the fan basically falls apart. Toxicity build i think.
  8. bulldogjeff
    2 Mar 2010
    Theres a tiny cir-clip that just pops off most fans to release the blades.
  9. stefan442
    14 Mar 2011
    Right, bought some bits.
    Still need to buy some braiding, i rekon 3 mm for individual cables. Need white/black and possibly i might mix in some red. And i need some 6mm black or white heatshrink. undecided on colour, maybe both.
    Im going to paint all thumb screws and try paint fan screws, see how the paint holds out when i re use them.
    Pics below of current progress:
    Tomorrow i will finish taking case apart, make some cabling holes and i will remove the grills infront of the intake fans on the front of the case! And i may possibly prime the case......
  10. stefan442
    14 Mar 2011
    I did write up a mssive todo list and a list of what ive done. But closed tab by accident as ive been for a few beers whilst letting the paint dry! ill post some more info 2mora.
    Photos so far
    Criticism welcome....
    Thanks,
    stefan
  11. Blarte
    15 Jul 2008
    constructive criticism would be better though Stef, nice start
  12. stefan442
    14 Mar 2011
    Right.
    Im waiting on some sleeving and black rivets from mdpc. Would recommend buying from that site, got a really nice personal email and a thorough written tutorial for sleeving and some pics to help me out a bit! :D As soon as i get that i can put the case back together and sleeve up.
    http://en.mdpc-x.com/mdpc-sleeve/sleeve/sleeve-small-red.htm
    Im going to add either red or white light now. I decided to add red because the psu has red connectors and a 3rd colour would add to the case. I think it would anyway.
  13. djzic
    djzic Bokehlicious!
    8 Nov 2010
    ...you forget about the personalized drawing :D
  14. Mataten
    Mataten What's a Dremel?
    5 Feb 2011
    Nice start of your mod Stefan,I will follow it to the end because I´ve got a 300 myself.
    I have been doing some thoughts what to do with it.
    Now I have an inspiration source,if you dont mind?
    Grrreat work so far!:dremel:
  15. stefan442
    14 Mar 2011
    Have done this with both intakes. Looks alright and the fans fit in just fine
    Woop, came within 3 days. Superb service and superb product!! mdpc Cheesecake
    Top quality
    Black rivets being used
    I couldnt sleeve every single cable into my psu, there just wouldnt be any room! I almost need to extend the psu box and have the cables going though that then out the back. Its also very very hard to put the side cover of the antec back on. Just not enough room for all them cables. I was considering cutting off the cables i don't use and hiding them back in the psu so i could gain some space.
    Threw the pc back together as i wanted to play some shogun tw2 and build something on minecraft! I still need to sleeve sata cables, sleeve pci-e power, tidy cables, side window. I bought 2 6led strips off ebay for £4.99. They have a sticky back, just ran them up the hdd cage. The light shines through the front fans quite nicely. Also i need to either repaint all thumb screws again, or just buy some coloured ones. As my paint job on them didnt come out as planned!
    law99 likes this.
  16. law99
    law99 Custom User Title
    24 Sep 2009
    That's looking good man. I really like the way it all comes together in white.
    In fact, when I get some time and mony, I'm going to copy you I think. There is another mod by another bit tech user somewhere but I forgot to book mark the page!:waah:
    Edit: Subsciribed.
    What's that black stuff called that wraps around the holes?
  17. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    ^^ C-strip or edge trim
  18. stefan442
    14 Mar 2011
    i call it grommit strip.
  19. postmangav
    postmangav What's a Dremel?
    3 Mar 2011
    Nice mods. Looking at getting either a 100 or 300 in the next few weeks. Great job on the cables btw.
  20. stefan442
    14 Mar 2011
    This is it for now...
    i want to purchase an ssd also ill purchase a new gfx card at some point! But to be honest come the new year i would like to upgrade to SB or IB which means a total rebuild. Id probably buy a new case and move all of this into it and turn it into a media pc/server and put it downstairs next to the tv!
