Antec at Computex!
Discussion in 'Hardware' started by acemodder, 5 Jun 2018.
  1. acemodder
    acemodder Official Antec Rep
    13 Apr 2013
  2. Zak33
    Zak33 Staff Lover of bit-tech Administrator
    12 Jun 2017
    that makes me smile...... a lot :)
  3. Zak33
    12 Jun 2017
    what's b-die?
  4. spolsh
    spolsh Multimodder
    4 Feb 2012
    Samsung B-die ... the most likely to work at high speeds in Ryzen systems. (As usual, results may vary, silicon lottery and so-on applies)
  5. acemodder
    13 Apr 2013
    B-die is Samsungs top rated chips.
  6. GeorgeStorm
    16 Dec 2008
    As others have said, it's the go-to mem chips for overclocking.
  7. RedFlames
    23 Apr 2009
    B-die iirc refers to the chip design revision, So for example you have Samsung B-Die, Micron H-Die, Hynix A and M-Die.
    And to echo what others have said -
    Samsung B-Die is preferable iirc because it can do high speed/low latency quite easily [3200MHz @ CAS14 being the sweet spot it seems] and some of the others [Hynix iirc] didn't/don't play nice with ryzen.
  8. Guest-56605
    Guest-56605 Guest
    Hynix memory, to be fair sucks.
  9. David
    7 Apr 2009
    The RAM table suggests mostly run of the mill high CAS stuff, prolly Micron or Hynix.
    Hynix does indeed suck the big one, for Ryzen builds. Pretty much 90% of Corsair stuff seems to be Hynix.
    Guest-56605 likes this.
  10. adidan
    25 Mar 2009
    Will be good to hear the specifics.
    No doubt a mix depending on the set from what this thread is making me believe.
  11. Zak33
    12 Jun 2017
    every day's a school day :) cheers all
  12. acemodder
    13 Apr 2013
    Those that need to know, know.
    Those that don't need to know, don't.
  13. Zak33
    12 Jun 2017
    i just moved from one to t'other
  14. acemodder
    13 Apr 2013
    Here is a cool pic of our plasma RGB memory.
  15. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
  16. Anfield
    Anfield Multimodder
    15 Jan 2010
  17. adidan
    25 Mar 2009
    RGB, sorry does nothing for me.
    Just enough blue to light up my keyboard and mouse in the dark thanks.
    The little bit that comes out the bottom of my Antec case is acceptable as it lets me see where the USB ports are.
  18. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    Project X case looks like a potential lawsuit from Cougar over their Conquer model.
