Does anybody know the Watts and the Amps for these fans? Even Antec don't have that info on their web site. I want to connect them to a fanbus. I have four coming off one molex. They do look smart.......:dude:
i wouldent worry about it....an 80mm antec fan and 3 leds, are not going to over power anything........leds are generally milliamps each, so dont even worry about them......only downside of these fans are if your going to run tham at a lower voltage then usual, the lights dim with the fan....
Yep I've got a meter, I didn't think about wiring the led's up seperate..... Not a bad idea..........
Does anyone know if you can get these clear fans with RED LED's? I love the bloo ones but i need red ones for my new project. If they're not available yet, will they be soon? Thanks AoD :dude:
