Modding Antec Cases And Lit Case Badges
Discussion in 'Modding' started by mookboy, 1 Oct 2002.
  1. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    I was thinking of buying this but I am little worried about the inverter. What I want to know is this:
    - With my case being a Cheiftec/Antec Dragon, the badge would go on the door therefore with some wiring running thru into the case interior from the back surface of the door itself. Looking at the length of wire between the badge and the inverter it looks like the inverter would also have to be mounted on the door.... so, is this a problem in terms of me injuring myself (I read someone say they got a slight shock of an inverter)? Or, is there a way I could make an extension lead - is this easy?
    Sorry about the n00bness but I'm not good with this sort of decision making... :waah: :waah:
  2. Lazy
    Lazy Meow?
    13 Nov 2001
    an extension wire would be simple and the best idea :)
  3. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    What sort of connections do inverters use? Apologies in advance... :rolleyes:
  4. Lazy
    Lazy Meow?
    13 Nov 2001
    the inverter will plug into your psu using a 4 pin adapter.
    you just need to cut the wire insert some more wire and solder :)
