Hardware Antec Kühler H20 650 Review
Discussion in 'Article Discussion' started by Combatus, 16 Apr 2014.
  1. Combatus
    16 Feb 2009
  2. JCBeastie
    JCBeastie What's a Dremel?
    10 Nov 2005
    Wouldn't touch it with a barge-pole. What happens when the fan fails? I've had several new fans on CPU heatsinks, graphics cards and cases fail in the first few months; I'd want to be able to easily replace them. This thing is so integrated you'd have to return the whole unit. Sure you could add a fan behind it but that's not likely to perform well.
  3. Sim0n
    Sim0n rm -rf /
    14 Dec 2001
    JCBeastie, more importantly, the fan motor is the pump motor in this case. So if the fan stops, the fluid movement also stops.
    With no "software control", theres nothing to TELL you the fan/pump has broke, other than when your PC shutdown because the CPU is boiling away with no active cooling.
    Worrying, surely ?
  4. biojellywobbles
    biojellywobbles Minimodder
    12 Feb 2011
    Surely it's only as worrying as if the fan stops on an air cooler? Modern CPUs are not really harmed by overheating any more as they will throttle or shutdown in the event that things get a bit too hot.
  5. StaticFX
    StaticFX What's a Dremel?
    4 Feb 2014
    just an FYI - the Fan motor is NOT the pump motor. I have pulled it all apart and managed to change the fan.. have not had the chance to try it out yet.. hoping noise will be better. I could just plug the fan into the MB for better control if I want
Tags: Add Tags
