Hardware Antec Kühler H2O 920 Review
Discussion in 'Article Discussion' started by arcticstoat, 21 Jul 2011.
  1. pizzanbeer
    pizzanbeer New Member
    19 Jun 2009
    I would like to see a self contain liquid cooling set up for gpu.That what makes the most noise in my system.
  2. Lockon Stratos
    Lockon Stratos I Will Snipe You!
    19 Apr 2010
    I got one of these the moment SCAN had it in stock. and i have to say I am very happy with it. even though idle temps are 1 or 2'c higher then the my Frio which i was previously running with 2 Akasa Apache PWM fans. Ive set my custom profile to 25|50 but on the occasionally change it to 30|50 if the fans gets a little too loud.
    Its a great cooler. no doubt about it, but at around £70 its not really worth the price premium over a Frio. as the Frio also makes a lot less noise when the CPU is under load.
    I havent yet put this thing through a Prime 95 stress test yet. but the coolant temperature rarely goes over 38'c unless we were experiencing ambient temps of 28-33'c like a few weeks ago.
    Keeps my Overvolted 2500k@4.9Ghz pretty chilled. usually I get about 70'c when i put my 2500k through prime95. I should really retest it some time. It would be interesting to see how high temps get
  3. PingCrosby
    PingCrosby New Member
    16 Jan 2010
  4. PingCrosby
    16 Jan 2010
    Same here, I'll be sticking with my Frio a while longer yet. These things are way too expensive at the moment.
  5. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    you should look up the Coolit Omni its exacly what your looking for
    http://www.coolitsystems.com/index.php/omni.html
    however the big drawback is its lack of support
    only
    "nVidia® GeForce® GTX480
    nVidia® GeForce® GTX470
    ATI Radeon™ HD 5970
    ATI Radeon™ HD 5870 "
  6. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    :rolleyes:
  7. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    And you still make dumbass comments?
  8. dramatik
    dramatik Member
    9 Feb 2011
    LOOL, hmmm might have to retire my megahalems for something else.......
  9. Claave
    Claave You Rebel scum
    29 Nov 2008
    NOTE: We've removed the AMD cooling figures, as we've since found an irregularity with the AMD thermal test system. Bit-tech prides itself on being accurate first and foremost so we don't want to publish possibly inaccurate information for a second longer than necessary. We will update the situation as soon as possible.
Tags: Add Tags
