Modding Antec LED fans
Discussion in 'Modding' started by sinizterguy, 5 Oct 2002.
  1. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    If I buy these fans, can I run them on 7v to reduce noise ?
    or will that kill the LEDs ?
  2. Cyberbob:-)
    Cyberbob:-) Minimodder
    16 Jun 2002
    I've tried it, It didn't work for me the Led's went really dimm and they flashed too......
    I've ran the Led's off a seperate molex. Just snip the red wire,make sure you snip the right 1. and run it to a molex, you can leave the black 1 where it is...I ran mine to a switch so I can switch the LED's off if I want..........:D
  3. sinizterguy
    25 Jul 2002
    So i'd have to use two molexs instead of one.
    Can i run two sets of LEDs off the same cable ?
  4. Cyberbob:-)
    16 Jun 2002
    Well I've ran 4 led'ed fans of the same molex with no problem.........
    If your are not sure about anything, just ask..........
    :idea:
  5. sinizterguy
    25 Jul 2002
    Will dp :D
    Thx
