Modding Antec Minuet + 9800 PRO + AGP RAISER
Discussion in 'Modding' started by -SilentNight-, 29 May 2004.
  1. -SilentNight-
    -SilentNight- Hardcore pro gamer
    24 Jan 2004
    here is the question will those fit into case?
  2. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    why do you want that risercard?
    how tall is the risercard BTW?
  3. -SilentNight-
    24 Jan 2004
    coz minuet it matx case with lowprofile cards... and riser size is
    95mm x 29mm
  4. khendar
    khendar What's a Dremel?
    25 May 2004
    The only way to find out would be to measure how far above the connectors the slot is on the riser, then measure the width of the 9800 and see which is more...if the card is wider then its going to hit the other expansion slots...
    [edit] Please find attached a dodgy diagram :D
  5. -SilentNight-
    24 Jan 2004
    nooo!!! i din't mean that i mean horizontal so will it fit into case
  6. khendar
    25 May 2004
    That IS horizontal...you want the gfx card to be parallel to the motherboard right ? Thats the purpose of the riser ?
    The main thing stopping you is going to be the heatsink and fan (red bit on diagram) on the 9800...If its to wide (Y on the diagram) then its not going to fit. The fan/hs is going to be sitting on the pci slots...
    Unless I've got it wrong....???
  7. -SilentNight-
    24 Jan 2004
    [​IMG] so gpu will go opposite of PCI
  8. khendar
    25 May 2004
    Slightly better diagrams this time :D
    ( blue = riser, orange = 9800, red = heatsink, white = pci )
    This is what you are trying to do right ? You want the gfx card mounted horizontally, parallel to the motherboard.
    The problem you will have is there is not enough clearance between the heatsink and the pci slots. If if doesn't actually touch the slots physically, there probably wont be enough air getting to the fan to cool the gpu. Plus I'm pretty sure those cards are heavy, so there may be too much strain on the agp slot and riser card...
    I think :D
  9. ohcyt
    ohcyt What's a Dremel?
    7 Jan 2004
    that's not possible, with that riser card the graphix card will go on top of the PCI slots...
  10. khendar
    25 May 2004
    Hmm I have no idea now...I went back to my voodoo5 to check out the port and its backwards to what I thought it was...
    I need sleep :(
  11. Smilodon
    25 Mar 2003
    so.. where do you want it then? on top of the NB and the CPU? you know there is no room there... unless you are running an old 486 heatsink :p
