Antec NeoPower 480 and SLI
Discussion in 'Hardware' started by Twinsen, 26 Dec 2005.
  1. Twinsen
    Twinsen What's a Dremel?
    28 Aug 2003
    Ok, I think my Antec Neo is cabable of doing SLI, but I'm not entirely sure. I'm thinking of either getting another SLI power cable from Antec, or would a PCI spliter be stable enough?
  2. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    PCI splitter? :eyebrow:
    If I recall correctly basically all PCI-E video cards have a two molex to six pin connector adaptor; that will let you do SLI just fine.
  3. Arkuden
    Arkuden mow?
    9 Jul 2004
    if your neo says its sli ready it should have at least 2 PCI-E 6pin molexes on them. Most of the time video cards that are labeled for SLI sales will includ an adaptor.
  4. *mat-ster*
    *mat-ster* What's a Dremel?
    10 Mar 2002
  5. hitman012
    hitman012 Minimodder
    6 May 2005
    From searching around, it appears the Neopower 480W has 2 x 6-pin PCI-E connectors. It should run the cards just fine.
  6. *mat-ster*
    10 Mar 2002
    Reading through the user manual (my copy) for NEOPOWER 380/480 version 1.0.5 (5/5/04)
    Actually you only get one dedicated cable "PCI"
    11. One set of wires with a 6-pin PCI Express graphic card connector at one
    end and a 6-pin PSU connector at the other end
    The key thing this will not be a problem most (all) Graphics cards are supplied with an adapter.
    http://www.antec.com/uk/productDetails.php?ProdID=05481#
    Please note you should have the power supplied on a different cable leading from the PSU to supply clean power.
    Matty :)
  7. Twinsen
    28 Aug 2003
  8. *mat-ster*
    10 Mar 2002
    Kool find Twinsen,
    I sleeved all my own mind :)
    In UV reactive Yellow and purple :baby:
    Matty
