Hardware Antec One review
Discussion in 'Article Discussion' started by brumgrunt, 26 Jun 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    Loved the 300 and would probably go for this if I was buying a budget system.
  3. murraynt
    murraynt Modder
    6 Jun 2009
    I think id stretch and get the 300r. It looks like it's in a different league, haven't actually used one though.
  4. Sutura
    Sutura What's a Dremel?
    23 May 2011
    I really like this case. I'd love to see it in mATX option. There's something about the soft lines on the top exhaust fan I find really appealing. Hope they make a smaller one as well :)
  5. theshadow2001
    3 May 2012
    I really hate my antec 900 case. Cable management was a nightmare. Collision issues between hard drives and graphics card. Loud fans. Awkward to do any work in the case. No cutouts for the heatsink. It just goes on. For some reason at the time I bought it, the internet was full of people saying how great it was. Anyway this looks like a slight improvement but not much. Also I notice there doesn't seem to be a hard drive in the example build. Just as well probably as the hard drive bay seems to be a place for cable storage.
  6. Valinor
    Valinor What's a Dremel?
    30 Oct 2010
    I'm sure bit-tech didn't like the 900 either..
    Oh no, they didn't
    So if they're scoring this one well then I'd think that it's definitely improved.
  7. Elton
    23 Jan 2009
    I'm not a fan of Antec cases ever since they stopped really focusing on the epic enclosures such as the P1xx series.
    Now those were cases. A bit boring yes, but they were quite moddable and generally aesthetically pleasing.
  8. docodine
    docodine killed a guy once
    10 Feb 2007
    How does the NZXT Source 210 Elite compare?
  9. wavidek
    wavidek What's a Dremel?
    27 Jun 2012
    Im thinking to either get this or the 300 but im afraid that the Asus GTX670 DCU II wont fit...and i wanted to be able to SLi in the future
  10. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    The 670 will fit fine, they said that a 680 can fit so I'm sure there will be no problems :)
  11. Baz
    Baz I work for Corsair
    13 Jan 2005
    Just make sure power connectors are top and not end mounted!
  12. Vengence93
    Vengence93 What's a Dremel?
    15 Mar 2011
    Is it me or does that CPU Cooler look like its stretching out just a little
  13. jrs77
    jrs77 Modder
    17 Feb 2006
    I have an Antec Threehundred, which I modded a few years back. And just like the Threehundred this "One" makes a good basis for a casemod.
    The only thing I really dislike is the amount of 5.1/4" bays. Two should be more then enough actually, as you can fit an optical drive and a fancontroller or resbay there. Anything more than that is wasted space imho.
    In my Threehundred I mounted the HDDs in the 5.1/4" bays which improved airflow alot, and I'd recommend it for the One aswell.
Tags: Add Tags
