Reviews Antec P110 Luce Review
Discussion in 'Article Discussion' started by bit-tech, 16 Oct 2017.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. kent thomsen
    kent thomsen What's a Dremel?
    9 Jul 2011
    Nice to see Antec back with a good looking and well made case. I would have liked to read a little about noise, though, low noise has always been one of the key features of an Antec case.
  3. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    To be fair, the cooling and noise aspect of cases "out of the box" is almost entirely a moot point - 90% of users will replace the fans for their favourites, add a load more to boot, then fill it with components that will no doubt have very different levels of noise generation.
    I really like it, even if it is a very samey to the likes of the Fractal Define, NZXT S340, Corsair 400C etc... But the thumbscrews that hold the side panel on will drive me BANANAS if the "A" logo doesn't line up perfectly vertical when tightened.
  4. Guest-56605
    Guest-56605 Guest
    :nono: Herein lays the problem with manufacturers, same samey different price tag...
    TJ07 curves and innovation, yes please :thumb:
  5. Wakka
    23 Feb 2017
    If Silverstone released a new TJ07, with the 5.25" bays replaced with a radiator support, updated connectivity and fully painted internals, I'd cut my own kidney out to buy one.
    Guest-56605 likes this.
  6. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Those thumbscrews on the glass side panel make me irrationally angry. They just ruin the clean lines, and like Wakka I think I'd have to make sure that all of the "A" logos were perfectly aligned :D
  7. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Yeah, no real need for those "A" logos.
    There should be a Silent version of this case coming with sound deadening fitted, based on what we saw at Computex.
  8. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    This sounds a darn sight better than the P8, seems steps are at least being taken in the right direction. That lighting control is a bit of a mess though.
  9. Vault-Tec
    30 Aug 2015
    Without sounding like a wind bag Antec really need to stop imitating and start innovating again. The original Sonata etc were miles ahead of the competition but these days they just copy every one else :(
  10. RedFlames
    23 Apr 2009
    Remove the Antec logo and the 'A' Thumbscrews and you'd look at it and think 'that case could've been made by literally anyone'... I'm struggling to see anything new, unique or even remotely interesting about the case...
    Also tempered glass side panels is the current trend I wish would naff off and die...
  11. Guest-56605
    Guest-56605 Guest
    I think the last Antec product I genuinely liked was the Skeleton - even then, that was a Test Bench.
  12. TheDarkSide
    TheDarkSide What's a Dremel?
    22 Feb 2011
    0.8mm thick aluminium for the outer panels? Isn't that flimsy?
  13. Dogbert666
    17 Jan 2010
    The outer, front-facing part of the front panel only. The core of this panel is strong plastic, but very little is exposed thanks to the covering.
  14. Vault-Tec
    30 Aug 2015
    I genuinely liked the Lanboy air tbh. Again, very innovative.
  15. Ice Tea
    Ice Tea Multimodder
    26 Jul 2009
    I'm getting fedup with all these glass panel cases as well.
  16. acemodder
    acemodder Official Antec Rep
    13 Apr 2013
    Yes the Silent version will be available in December.
    The glass version is available this week from UK resellers.
  17. pbryanw
    pbryanw Minimodder
    22 Jul 2009
    Small point, but I really hope other case manufacturers copy the side ejecting filter on the bottom this case employs. I rarely clean the one on my Corsair case because it’s a rear sliding one, blocked in by my cables.
    Also, I can’t see a reset button on the top I/O panel - does it have one? It’s something I’d miss, as the one on my case comes in handy from time to time.
Tags: Add Tags
