Cases Antec P193 front panel audio noise
Discussion in 'Hardware' started by giskard, 26 Jan 2010.
  1. giskard
    giskard System builder
    21 Nov 2009
    The front panel audio jack on my Antec P193 is quite noisy - with a pair of earbuds plugged in and no audio playing, I can hear a faint but very audible electrical interference that sounds like squelching and buzzing. I've plugged in the case's HD audio connector into the correct header on my P6T SE mobo and HD audio is enabled in the BIOS. I don't get the same interference with the earbuds plugged into the mobo's green audio socket, though having said that, there is very slight but otherwise not very noticeable noise.
    Is this sort of interference just a fact of life with front panel connectors or is there anything I can do about it?
  2. GoodBytes
    20 Jan 2007
    It's probably just your sound card, usually they boh have heavy static.
    If you want great non staticy sound, you need a dedicated sound card. Just make sure the sound card has a plug to attach the front panel sounds... mine (X-Fi) doesn't.
    You may want to look at ASUS Xonar.
  3. giskard
    21 Nov 2009
    I don't have a sound card, just the onboard HD audio that's part of the motherboard
    I've since seen quite a few posts similar to my OP as far as Antec P-series cases are concerned - Antec have been replacing the cabling and audio sockets under warranty so I might raise a support ticket and see what happens.
  4. GoodBytes
    20 Jan 2007
    If it outputs any sound... it's a sound card... integrated or not... it's still a sound card.
    I've since seen quite a few posts similar to my OP as far as Antec P-series cases are concerned - Antec have been replacing the cabling and audio sockets under warranty so I might raise a support ticket and see what happens.[/QUOTE]
    ok
  5. wyx087
    15 Aug 2007
    also hearing noise on my Antec P182, im thinking it's to do with the case rather than the sound chip.
