Cases Antec P380 Watercooling Capabilities.
Discussion in 'Hardware' started by acemodder, 11 Dec 2014.
  1. acemodder
    acemodder Official Antec Rep
    13 Apr 2013
    Hi guys.
    Well previously we released the Antec 1900 and some of the community suggested it was not watercooling ready out the box. I thought it would be rude not to show what is possible with the new Antec P380 out the box using just a screw driver!
    Firstly is the sleek and stylish exterior!
    Then a shot of the inside reveals a nice roomy internal design.
    Two 140mm fans pre-installed in the top for you
    But space for a 3rd fan :)
    So the first thing I did was rip out the fans and try a 360mm thick rad.
    Plenty of room up top
    Then I decided to remove all the HDD and ODD bays. It was a few screws, nice and easy.
    Then I put my 360mm rad in the front.
    Oh and 3 fans.
    Why have 3 when you can have 6 though? And 3 bay HDD cage fitted in the reccessed position now :)
    And finally the dust filter in front of the front 3 intake fans for good measure.
  2. acemodder
    13 Apr 2013
    Some pics here showing a 240mm rad and the upper HDD bay and 5.25" bay in tact, remeber you can also fit a 360mm in the top with the ODD bay installed.
  3. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    Quite a nice looking case.
