Hardware Antec P50 Window Review
Discussion in 'Article Discussion' started by Combatus, 16 Dec 2015.
  1. Combatus
    16 Feb 2009
  2. Bumfluff101
    Bumfluff101 Minimodder
    10 Jan 2010
    Now torn between this and the carbide 240 - though I think there are some problems with some gpus fitting as they are to wide hmmm......
  3. gosh
    gosh Minimodder
    20 Oct 2009
    been after a mini-itx case for a while, so hard to decide without seeing it in the flesh but for £40 this seems better for under-desk use than the slightly cooler and shorter core 500, choices.
  4. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    How much better at cooling would this case be if the front was mesh (on the motherboard side at least) with a dust filter?
    Would probably look real good with it too.
    Edit: Scan now have it in stock at just under £40 ...bundled with the red mesh top alternative :)
  5. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Just because it bugged me when reading it...
    'it may not be as fancy or quiet as water-cooling friendly'
    Think you meant quite, but regardless, thanks for the review.
  6. SuperHans123
    SuperHans123 Modder
    27 Dec 2013
    Shockingly plastic build quality on the Carbide I thought. I have a SilverStone Temjin now(Slightly old school|) but night and day compared to the Carbide. This looks a way better bet than that plastic sack of siht.
  7. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Haha good spot! Fixed - thanks!
  8. gosh
    gosh Minimodder
    20 Oct 2009
  9. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    This is such a rip off of the Corsair Air 240 :(
  10. ziggy444
    ziggy444 What's a Dremel?
    26 Sep 2011
    Can you check the dimensions of this case please? Scan Computers has it down as 210 x 20 x 300 mm (W x H x D), where you have it as 260 x 355 x 355 (W x D x H).
    Thanks.
  11. Baz
    Baz I work for Corsair
    13 Jan 2005
    Imitation is the most sincere form of flattery.
  12. Dogbert666
    17 Jan 2010
    I'm fairly sure this case isn't 20mm tall :)
    You're looking at the dimensions of the extra red roof bracket on Scan. Further down you'll see the dimensions are the same as we've listed!
  13. qLiMaX
    qLiMaX What's a Dremel?
    18 Dec 2015
    Ventilation for GFX card does not look good as there is no holes for air flow on the bottom of the case.
Tags: Add Tags
