News Antec reveals P190 case
Discussion in 'Article Discussion' started by Tim S, 15 May 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. ychamp
    ychamp What's a Dremel?
    20 Sep 2005
    give me one.
    and wow lots of fan s there...
    hopefully will be as good as the p182 and p180
  3. DougEdey
    5 Jul 2005
    Is this the 20Kg jobbie? And if so does that include the dual PSU?
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    The price is a bit frightening - £287.53 at ebuyer. :jawdrop:
    43lb (20kg) out of the box. One for a castors mod. ;)
  5. capnPedro
    11 Apr 2007
    Pure quality!
    The p182 should be my next case, this beast just looks too... huge. And the price, oh the price. £290 with two PSUs isn't that bad though, if you're paying about £55 for a PSU, it means the case is £180. Now compare that to a big Lian-Li. However, I'd like to see these PSUs tested first.
  6. Guest-23315
    Guest-23315 Guest
  7. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    The 200mm fan is nothing new: Antec put the exact same fan in the top of their 900 model.
    That said, I'd still rather have a V-1000.
  8. Baz
    Baz I work for Corsair
    13 Jan 2005
    love antec, an excellent company. I've just had to order some new drive rails for my antec p160, purchased 4 years ago, and they're sending them to me free....from AMERICA!
    go antec!
  9. kosch
    kosch Trango in the Mango
    12 Feb 2005
    hmm the question is though are the PSU's any good and can you buy a version without the PSU's in?
  10. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    Antec PSUs have always been right up there with the best, I can't imagine they'd skimp there as they probably have most of the high quality componentes to hand from their TruePower and Trio lines.
    Does this mean we can expect yet another p180 price drop :D
    oh and anyone gunna review the new Antec Sonata III??
  11. completemadness
    completemadness What's a Dremel?
    11 May 2007
    hold on did someone say dual power supplies :jawdrop:
  12. Krikkit
    21 Jan 2003
    Indeed they did. Great news for server setups tbh, replace that dual job with a proper pair of PSU's and get some nice redundancy going on. :D
  13. completemadness
    11 May 2007
    then again then lian li 2000+ will take a dual PSU (if you get the different mounting plate at the back)
    there are like 3 i think, 1 for 1x psu and 2x 80mm fan, and 2 for dual PSU's (which aren't standardised i think ... sigh)
  14. Jodiuh
    Jodiuh What's a Dremel?
    17 Mar 2006
    MOVE THE BOTTOM FAN IN FRONT OF THE HDD'S!!!!
  15. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    It sounds like a modded P180 with dual PSU's and a few bigger fans
  16. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    looks like a great case for air cooling, but not so good for h20 cooling.
    dual psus will take some space away for bottom 120.2 rads : /
    i love my p180b but frankly, it was quite a hassle to watercool and cable management is a bit of a problem.
  17. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    I would like one without the duel PSUs, and use the extra space for Water. Else I will stick with the V2000 I'm planning on getting.
Tags: Add Tags
