Cases Antec Twelve Hundred (v2) and USB3?
Discussion in 'Hardware' started by trekkypj, 2 Mar 2011.
  1. trekkypj
    trekkypj Forward Momentum!!!
    23 Jun 2010
    Hi all,
    I have salted away an Antec Twelve Hundred (v2) case to build a new pc (eventually).
    Just read that they updated the case recently to add USB3 ports. Anyone know if the front plate can be swapped to add USB 3 to the existing case? Is this even necessary?
  2. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    the usb 3 ports add 4 more wires but usb 2.0 backwards compatible.. probably be a good idea to ask on the antec forum first.. but it looks as though you can take out the port and replace it quite easily
  3. murraynt
    murraynt Modder
    6 Jun 2009
    Can you update this if you find anything trekkypj.
    I have a USB 3.0 Back plate from my Asus P8P67 that could make lovely USB 3.0 front connections for my 1200.
