Distributed Anti-Virus King (Panda vs Kapersky vs McAfee vs AVG vs Norton)
Discussion in 'Software' started by Moyo2k, 4 Aug 2009.
  1. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    Would like to add microsoft to that list, although its only in beta rumblings are that it is in fact very very good
  2. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
  3. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    I've got COMODO Internet Security on mine, and two other PCs in the house.
    Excellent, always picks things up.
  4. TechDante
    TechDante What's a Dremel?
    12 Sep 2008
    was wondering if anyone has the yoggiy gatekeeper pico and if they rate it at all
  5. adam_bagpuss
    24 Apr 2009
    NOD32 is good but i run business edition which is very good. stops the nasties at the server.
    avast is also very good. picks up stuff that AVG, norton etc dont detect.
    AVG was ok until i found out that the free edition is at least 30 days out of date with virus updates.
    Norton should be burned and does nothing but harm to your PC while making it run like a snail.
  6. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    I'm trying out Anti-Vir atm, with highly secure firefox (configure perfectly)
  7. Mister_Tad
    27 Dec 2002
    Another vote for NOD32
    Oddly, the above table says NOD32 utterly sucks, however it lists version 2 which is a good few years old - its on 4 now
  8. davidfield375
    davidfield375 Hardware Mods
    3 Feb 2009
    Even some of the best antivirus programs fail to pick up common things like browser hijacking....although do to my computer's browser getting hijacked, I did find out that be renaming things like spybot.exe to spybot3.exe for example would let you run the program which can be disable by a number of viruses.
  9. mm vr
    18 Nov 2007
    Don't say such things unless you've actually tried the newest version (2009). It's pretty good. Only uses ~10 megs of RAM for example.
    But yeah, I agree with that if older versions are discussed.
    Abhorsen likes this.
  10. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    tbh if the microsoft defender AV thingy is good enough i can see a lot of these companies going out of business. it is going to be free isnt it?
  11. Mister_Tad
    27 Dec 2002
    Until the EU demands that MS remove the functionality...
  12. [PUNK] crompers
    20 May 2008
    ah yes, well foreseen
    I guess with IE im quite glad its gone from W7, but for something as mundane as AV im prepared to just let MS handle it!
  13. AstralWanderer
    AstralWanderer What's a Dremel?
    17 Apr 2009
    Arguably this would be an improvement. Microsoft should focus on making Windows less vulnerable to malware in the first place (there has been progress here, but at a glacial pace) and fixing vulnerabilities found in its products more quickly, leaving detection to third parties.
  14. ou7blaze
    ou7blaze sensational.
    5 May 2003
    I agree, being such a big company with such a high amount of resources at its disposal Microsoft is doing a terrible job especially as we all know prevention is the best form of protection.
    However if you think about it there may be a good reason for that. Perhaps some "payments" from AV companies? Wild guess I know but you never know with big corporations.
  15. kenco_uk
    28 Nov 2003
  16. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    You are thinking about Avast, yes. They have changed the interface to something usable now, though. It looks very clean :)
    But, How often do you use the interface anyway? The AV runs in the background, and for scanning specific files you just right click and choose scan.
    The sounds in Avast is very annoying, but those can be turned off. :)
  17. skybarge
    skybarge just chilling at work
    29 Feb 2008
    +1 for avast, -1 for the loud 3am wake up "your virus scanner has been updated". But you can turn that off as mentioned above :)
  18. Abhorsen
    Abhorsen Minimodder
    10 Apr 2008
    Agreed with the comment about Norton 2009, it is a much improved piece of software and should be judge on it's merits alone when comparing with others.
    I personally use ESET/NOD32 and have never had any trouble so can definately recommend it.
    As for freeware, i've only ever seen could reviews on Avira, though when people then say they use SpyBot and 'Insert other programs here' in conjunction, and then go to flame a product such as Norton for crippling a system it does make me chuckle, as most often than not, running all those leaves a larger footprint than others such as Norton.
  19. D3s3rt_F0x
    D3s3rt_F0x What's a Dremel?
    28 Oct 2004
    NOD 32 +1
    Fast lightweight don't have to stop doing other things just cause I fancy running a virus scan.
  20. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    haven't we had this exact same thread like 5 times in the last couple weeks?
