antivirus for vista and mac
Discussion in 'Tech Support' started by sotu1, 9 Dec 2007.
  1. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    hey guys,
    just wondering if you had any suggestions for anti virus programmes for my Vista desktop and also for my OSX Mac?
    I know people dont normally suggest antivirus for mac, but they're arrogant fanboys who'll get bitten in the ass one day and i dont wanna be one of them!
  2. OleJ
    OleJ Me!
    1 Jul 2007
    AVG Free for windows.
    Mac user myself but dunno of any anti-vir. A good firewall I can recommend on the mac though is "Little Snitch", it's user friendly and effective.
    The list of stuff that'll get you infected on windows is long, but if you don't install shady stuff, keep away from IE and use a good firewall then you're pretty much in the clear if you ask me. But hey even though I've never been infected (brains and luck) I still runnti-virus on my win machines.
  3. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
    NOD32 for the PC, and keep me in touch about any good AV for OSX...
  4. Neoki
    Neoki Minimodder
    26 Oct 2004
    avg:)
  5. Seth
    Seth What's a Dremel?
    14 Mar 2002
    i don't think i would bother with antivirus on the mac.
  6. koola
    koola Minimodder
    11 Jul 2004
    lol
    Don't visit warez/p0rn sites and you'll never need av.
  7. dragontail
    9 Jun 2005
    Dunno about you, I still rather not take the risk. Better safe than sorry imo.
  8. GoodBytes
    20 Jan 2007
    AVG Free edition... but it DOES slow down your widows startup as it perform a scan on some system files before they startup. By slow I mean up to 3 times slower (again it depends on your system).
    The best I found (but you have to pay), and serious reviews support my opinion, is Kaspersky. I recommend to get the Internet security version, as, for like 15-20$ (I have to check the price again) more then the anti-virus virus, you get internet security, which offers decently flexible features on my taste and does a very good job. Also it doesn't slow ANYTHING down, your system is always fast, even when you download/uploads stuff and surf the web.
    @koola, I already visited some sites, real sites, even good reviews sites and such and I the second I visited them, I had (at the time, when I was using the trial period) Kaspersky pop-up and alerted me of a Trojan-horse found in Firefox cached. I removed it, did a complete scan, reboot and scan, it was totally gone. The second I revisit the side, and ONLY that site at the moment, again same thing happen. The next day, the site was safe. That specific situation was not the first time, it occurred to me (when I had AVG Free edition) on other sites, the problem is in this case AVG only alerts me when you visit the folder or do a system scan.
  9. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    sigh...like i said, fanboys who are arrogant dont believe in AV. i used to use AVG but it buggered up my bioshock game, so im not overkeen on using that again. not only that, but another AV prog was recommended but i cant for the life of me remember what it was called. i'll try little snitch, cheers for that tip
    any other suggesgtions for AV mac and vista?
  10. OleJ
    OleJ Me!
    1 Jul 2007
    There is Clam Antivirus which is free and multi-platform. It performs pretty well in reviews IIRC. I've used it on a linux server and even an XP machine a couple years back. It may still be a bit quirky to use, but I remember it as light and unobstructive.
    Oh yeah and it's apparently available for the Mac as well: http://www.clamxav.com/
    Edit: Dunno if they've added online protection, but it wasn't there last I tried it. Again: Just keep away from the dark side Luke and you will be fine.
    Also you may have been recommended NOD32 for Vista?
    /cheers
  11. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    i don't believe in antivirus whether i am running windows, mac or linux. careful browsing is the best antivirus. i'm definitely not a fanboy, but i may be arrogant.
    i run avg on other people's computers though. it seems to work all right, even if it does suck up some resources. nexxo was pimping some lightweight alternative in the crap apps thread, try reading through that.
  12. monkeybone
    monkeybone What's a Dremel?
    28 Jan 2005
    I use Avast on Vista and it works like a charm. As for Mac, no idea... sorry.
    Monkeybone
  13. xion
    xion What's a Dremel?
    23 Aug 2006
    2nd here... Avast all the way, effective, small footprint, and free... but it does scare the bejebus outa you when it finds somthing "Dont panic!"... (as klaxions boom out with flashing radiation signs) :D
  14. Glider
    Glider /dev/null
    2 Aug 2005
    Call me a fanboy as much as you like, but common sense is the best AV you'll ever find...
    I use Linux, that helps a lot... but on my Windows PC (which is running ever since 2000 or so) I never got a virus, and it's being used by the whole family. 1 hour of explaining how to use Firefox and not to open dodgy things == no need for an AV...
  15. Fophillips
    Fophillips What's a Dremel?
    9 Oct 2006
    IIRC, there has been a grand total of two (failed) viruses for OS X which were both well publicised before they became a viable threat.
  16. dragontail
    9 Jun 2005
    Did a bit of searching, and you can get Norton and Sophos for OSX. You can also get ClamXav, which is free. Only thing is it hasn't got official Leopard support yet (although the build for Tiger works fine).
